Spinning up some some k8s at the dc, I’m trying to have containers talk with other devices on the host network. Previously, I had used canal for a cni to accomplish this, but now I can’t seem to get canal to work as a drop in replacement for flannel using the current k8s bundles/charms. Looking at the canal bundle it seems it uses docker not containerd. I’m assuming the switch to containerd from docker is whats causing this breakage for me.
- Wondering if there is a canal bundle out there that works with containerd?
- Can I use docker instead of containerd (to get canal working) with the latest kubernetes charms, or do I have to use contianerd now?
Thanks!
