hello ,
i’m new to Juju and I have to use security tools with it such as : Nmap and Masscan but I couldn’t find any using Juju gui.
please advice me , is juju support these kind of tools ?
thanks you
hello ,
thanks you
Interesting question!
The trivial answer is yes. But there is no explicit support or extra tooling available for these tools. So a more nuanced answer is “it depends”.
To experiment with Juju’s capabilities in this area, you start by “bootstrapping”. To bootstrap into a cloud. You’ll need to add credentials.
juju autoload-credentials # required to access AWS, OpenStack, ...
juju bootstrap localhost learning
The “localhost” argument specifies that you wish to deploy to local containers. The “learning” argument is the name of the model that you’re creating.
After a few minutes, the root Juju container will be created. In Juju terminology, this is known as “the controller machine”. The controller is a software agent that’s actively monitoring the rest of the system. (Juju’s architecture requires an active agent, like Puppet, because it enables systems administration tasks as well just handling provisioning)
Let’s now create 2 blank containers:
juju deploy -n3 ubuntu
Located charm "cs:ubuntu-12". Deploying charm "cs:ubuntu-12".
We now have asked Juju to provision 3 more containers on our system. Each one believes that it is an independent machine. Juju has managed the firewall rules to prevent access, but now you wish to verify that and probe the (virtual) cluster with nmap.
The juju machines command will provide you with the private IP addresses of the instances that you’ve created:
juju machines
Machine State DNS Inst id Series AZ Message 0 pending 10.129.244.114 juju-d86839-0 bionic Running 1 pending 10.129.244.198 juju-d86839-1 bionic Running 2 pending pending bionic
Juju’s told us that machine 0 is at port 10.129.244.114. Let’s see what it’s listening to.
nmap -v 10.129.244.114
Starting Nmap 7.70 ( https://nmap.org ) at 2019-05-27 11:05 NZST Initiating Ping Scan at 11:05 Scanning 10.129.244.114 [2 ports] Completed Ping Scan at 11:05, 0.00s elapsed (1 total hosts) Initiating Parallel DNS resolution of 1 host. at 11:05 Completed Parallel DNS resolution of 1 host. at 11:05, 0.04s elapsed Initiating Connect Scan at 11:05 Scanning 10.129.244.114 [1000 ports] Discovered open port 22/tcp on 10.129.244.114 Completed Connect Scan at 11:05, 0.02s elapsed (1000 total ports) Nmap scan report for 10.129.244.114 Host is up (0.00012s latency). Not shown: 999 closed ports PORT STATE SERVICE 22/tcp open ssh Read data files from: /snap/nmap/249/bin/../share/nmap Nmap done: 1 IP address (1 host up) scanned in 0.13 seconds
Tip
Use
sudo snap install nmapif you need to installnmapon your machine
Tip
Take a look at this tutorial on closing
icmpif you wish to disable ping.
Juju makes it easy to test this from the inside of any of our hosts. For that, we can use juju ssh to log in. To start, we’ll install nmap on machine 1.
juju ssh 1
ubuntu@juju-d86839-1:~$ sudo snap install nmap
ubuntu@juju-d86839-1:~$ exit
Another command that’s useful is juju run.
Juju makes it simple to run the same nmap command as before, but from the point of view of machine 1 trying to port scan machine 0.
juju run --machine 1 nmap -v 10.129.244.114
