Juju 2.6.7 is expected to be released within a week. If you would like a sneak peek at one of its features, you’re very welcome to test it out. Juju’s edge snap includes a patch to support vSAN deployments.
Background
VMware provides an excellent private cloud automation solution called vSphere. Until now, Juju lacked the ability to deploy to deployments that made use of high-availability data volumes are known as vSAN.
We believe that Juju is the easiest way to deploy and manage a Kubernetes deployment on your cloud platform of choice. We would love to hear feedback if support can be improved further!
Test Juju on VMware vSphere backed with vSAN
To fetch the Juju edge snap, use the --channel
option.
snap refresh --channel=2.6/edge juju
juju (2.6/edge) 2.6.7+2.6-1d361a1 from Canonical✓ refreshed
Add a controller machine on your vSphere deployment. If you haven’t connected to vSphere before, follow these link to instructions for the add-cloud
command.
juju bootstrap <cloud-name> \
--config datastore=<datastore-name> \
--config primary-network=<network-name>
09:07:42 INFO juju.cmd supercommand.go:57 running juju [2.6.7 gc go1.10.4] ...
Once the bootstrap process is complete, deploy Charmed Kubernetes:
juju deploy charmed-kubernetes
Monitoring the deployment is easy in the command line:
watch -c juju status --color
To use Juju’s web interface, run juju gui
and it will provide you with your login details.
More info
This video introduction from August 2018 provides a good overview of managing a Kubernetes deployment with Juju via JAAS:
