Juju Terraform provider 2.4.0-rc1 release notes
29 September 2026
Requirements and compatibility
This release requires a Juju controller of version 3.6 or higher. Support for Juju 2.9 controllers is not available in the v2 track; 2.9 continues to be supported on the v1 track for security updates and bug fixes.
If you are using JAAS, this release requires a Juju controller of version 3.6.5 or higher.
This release is compatible with both Juju 3 and Juju 4 controllers.
New features
Enable HA on Juju 4 controllers
The juju_enable_ha action now works with Juju 4 controllers. Note that on Juju 4 the constraints field is ignored: new controller units inherit the constraints set at bootstrap time.
- Enable enable-ha for Juju 4 by [@SimoneDutto](SimoneDutto · GitHub) in [#1369](feat: enable enable-ha for juju 4 by SimoneDutto · Pull Request #1369 · juju/terraform-provider-juju · GitHub).
Bug fixes
- Updating the base of an application no longer fails when the charm revision is not pinned — if a
juju_applicationcharm block omitsrevision, changing thebasenow correctly recomputes the charm revision instead of failing. Tweak revision invalidator modifier by @kian99 in #1355 and [#1359](https://github.com/juju/terraform-provider-juju/pull/1359) (addresses #1351). - Null values in
juju_secretare rejected at plan time — anullelement in thevalueorvalue_womap of ajuju_secretresource now produces a clear error when planning, instead of an opaque failure during apply. Check secret value map elements for nulls and error on null by @ale8k in #1375 (addresses #1371). - Charm updates on Juju 4 — updating a Kubernetes charm to a different base now works on Juju 4 controllers. Set forceBase flag true for charm updates by @kian99 in #1366.
Documentation
Update the minimum supported Juju version in the docs. Update minimum supported Juju version by @luci1900 in #1358.
Explain how to use
terraform queryto import a manual deploy. Explain how to useterraform queryto import a manual deploy by @luci1900 in #1360.
Full changelog: Comparing v2.3.0…v2.4.0-rc1 · juju/terraform-provider-juju · GitHub
