The Juju team is happy to announce that the Juju Terraform provider v1.5.0-rc1 is released on 22 April 2026!
This release candidate has been pushed to the HashiCorp repository. For testing update your provider configuration to:
terraform {
required_providers {
juju = {
source = "juju/juju"
version = "1.5.0-rc1"
LINKS:
NOTES:
- This release requires Juju controller version 2.9.49 or higher.
- If using JAAS, this release requires Juju controller version 3.6.5 or higher.
- This release uses Juju client api code from the Juju 3.6.21 release.
ENHANCEMENTS
- Replace the CloudSpec controller facade call with calls to retrieve model summaries, cloud definitions, and bootstrap credentials by @alesstimec in #1158.
BUG FIXES
- Fix
juju_machineconstraints state inconsistency when constraints are inherited from model defaults rather than being set directly on the machine by @ale8k in #1157. - Fix
juju_ssh_keyto allow deletion of the final key within a model by @ale8k in #1188.
DOCUMENTATION
- Add a security overview document to comply with SSDLC requirements by @SimoneDutto in #1140.
- Update documentation landing pages by @tmihoc in #1165.
- Add the
sphinx-llmextension to make documentation more AI-friendly by @tmihoc in #1177.
CI & MAINTENANCE
- Add Go documentation for all exported types and methods by @alesstimec in #1083.
- Upgrade the Canonical Sphinx Starter Pack to v1.6 for inclusive language compliance by @tmihoc in #1141.
- Merge the 1.4 branch into main by @kian99 in #1162.
- Disable OS updates during machine provisioning in tests to significantly reduce test execution time by @kian99 in #1170.
- Update Juju dependency to 3.6.21 and Terraform plugin framework to 1.19.0 by @alesstimec in #1174.
Full Changelog: Comparing v1.4.3...v1.5.0-rc1 · juju/terraform-provider-juju · GitHub
