The Juju team is happy to announce that the Juju Terraform provider v0.21.0-rc1 candidate is released on 22 July 2025!
For specific dates for testing and release for the v0.21.0, please refer to the 0.21.0 Release Planning post.
This is a release candidate, it’s not yet pushed onto the HashiCorp repository, so testing with the release candidate requires you to pull it and change the TF plan to use the local provider.
$ git checkout tags/v0.21.0-rc1
$ make install
This will install the the provider in ~/.terraform.d/plugins/registry.terraform.io/juju/juju/0.21.0/linux_amd64.
Update your configurations to use the local candidate:
terraform {
required_providers {
juju = {
source = "registry.terraform.io/juju/juju" # (uses local provider repository)
# source = "juju/juju" (uses the Hashicorp repository)
version = "0.21.0"
LINKS:
NOTES:
- This release requires Juju controller version 2.9.49 or higher Juju.
- If using JAAS, this release requires Juju controller version 3.6.5 or higher.
- This release uses Juju client api code from the Juju 3.6.4 release.
ENHANCEMENTS
- Retry model creation when error is
TransactionAborted763 by @SimoneDutto - Wait for
hostnamefield to be populated when creatingjuju_machineresource 788 by @SimoneDutto - Add a
no-service-accountflag to thejuju_kubernetes_cloudresource to avoid service account creation by the provier 793 by @SimoneDutto - Using the custom type for
constraintsin thejuju_applicationresource 796 by @alesstimec - Waiting for machine deletion 761 by @alesstimec
BUG FIXES
- Store
juju_machineID immediately after creation 799 by @kian99
DOCUMENTATION
- Update
juju_offerdocumentation to useendpoints781 by @SimoneDutto
CI IMPROVEMENTS
- Fix UpgradeProvider tests by removing
PlanOnly = true782 by @SimoneDutto - Fix JAAS integration test 792 by @SimoneDutto
- Avoid model creation in JAAS tests for
juju_kubernetes_cloud797 by @SimoneDutto
