The Juju team is happy to announce that the Juju Terraform provider v0.20.0-rc1 candidate is released on 17 June 2025!
For specific dates for testing and release for the v0.20.0, please refer to the 0.20.0 Release Planning post.
This is a release candidate, it’s not yet pushed onto the HashiCorp repository, so testing with the release candidate requires you to pull it and change the TF plan to use the local provider.
$ git checkout tags/v0.20.0-rc1
$ make install
This will install the the provider in ~/.terraform.d/plugins/registry.terraform.io/juju/juju/0.20.0/linux_amd64.
Update your configurations to use the local candidate:
terraform {
required_providers {
juju = {
source = "registry.terraform.io/juju/juju" # (uses local provider repository)
# source = "juju/juju" (uses the Hashicorp repository)
version = "0.20.0"
LINKS:
NOTES:
- This release requires Juju controller version 2.9.49 or higher Juju.
- If using JAAS, this release requires Juju controller version 3.6.5 or higher.
- This release uses Juju client api code from the Juju 3.6.4 release.
ENHANCEMENTS
- BREAKING CHANGE to the
juju_offerschema. Theendpointfield is field has been removed in favor of theendpointsfield, which allows for definition of multiple endpoints in a single juju application offer 752 by @SimoneDutto. This change requires a simple change to your existing plans: you need to change fromendpoint: xtoendpoints: [ x ]injuju_offerresources. - Introduction of
juju_machineannotations 748 by @alesstimec. - Introduction of waiting for changes to take effect 738 by SimoneDutto, followed up by 738 that introduces a wait for application deletion and 760 that introduces a wait for integration deletion.
- Removal of the
juju_jaas_access_service_accountresource 759 by @kian99. Service account authentication can now be used with JAAS to upload cloud credentials directly to the controller.
BUG FIXES
- Fix for scaling up applications 730 by @alesstimec.
- Introduction of a custom type for
juju_machineconstraints 739 by @SimoneDutto, which fixes issues #734 and #729.
DOCUMENTATION
- Introduction of auto-generated RTD documentation 758 by @SimoneDutto.
- JAAS-related documentation improvements 746 by @tmihoc.
