The Juju team is happy to announce that the Juju Terraform provider 0.17.0-rc1 candidate is released on 18 Feb 2025!
For specific dates for testing and release for the v.0.17.0, please refer to the 0.17.0 Release Planning post.
Note that because this is a release candidate, it’s not pushed onto the HashiCorp repository, so testing with the release candidate requires you to pull it and change the TF plan to use the local provider.
$ git checkout tags/0.17.0-rc1
$ make install
This will install the the provider in ~/.terraform.d/plugins/registry.terraform.io/juju/juju/0.17.0/linux_amd64.
Update your configurations to use the local candidate:
terraform {
required_providers {
juju = {
source = "registry.terraform.io/juju/juju" # (uses local provider repository)
# source = "juju/juju" (uses the Hashicorp repository)
version = "~0.17.0"
LINKS:
NOTES:
- This release requires Juju controller version 2.9.49 or higher juju.
- If using JAAS, this release requires Juju controller version 3.6.0 or higher.
- This release uses juju client api code from the juju 3.6.0 release.
BUG FIXES:
