The Juju team is happy to announce that the Juju Terraform provider 0.15.0-rc1 candidate is released on 9 Oct 2024!
Thanks to all the contributors including @anvial @kian.
For specific dates for testing and release for the v.0.15.0, please refer to the 0.15.0 Release Planning post.
Note that because this is a release candidate, itβs not pushed onto the HashiCorp repository, so testing with the release candidate requires you to pull it and change the TF plan to use the local provider.
$ git checkout tags/0.15.0-rc1
$ make install
This will install the the provider in ~/.terraform.d/plugins/registry.terraform.io/juju/juju/0.15.0/linux_amd64.
Update your configurations to use the local candidate:
terraform {
required_providers {
juju = {
source = "registry.terraform.io/juju/juju" # (uses local provider repository)
# source = "juju/juju" (uses the Hashicorp repository)
version = "~0.15.0"
LINKS:
NOTES:
- This release requires juju controller version 2.9.49 or later juju.
- This release uses juju client api code from the juju 3.5.1 release.
ENHANCEMENTS:
- Support for JAAS access settings via the following new resources:
juju_jaas_access_cloudjuju_jaas_access_controllerjuju_jaas_access_groupjuju_jaas_access_modeljuju_jaas_access_offerjuju_jaas_access_service_accountjuju_jaas_group
- Support for adding kubernetes clouds to existing controllers with the new
juju_kubernetes_cloudresource.
BUG FIXES:
- feat: add computed uuid to model resource by @hmlanigan in #599
- fix: remove requirement on ca cert by @kian99 in #567
