The Juju team is happy to announce that the Juju Terraform provider 0.14.0-rc1 candidate is released on 9 Sept 2024!
Thanks to all the contributors including @anvial @hmlanigan.
For specific dates for testing and release for the v.0.14.0, please refer to the 0.14.0 Release Planning post.
Note that because this is a release candidate, it’s not pushed onto the HashiCorp repository, so testing with the release candidate requires you to pull it and change the TF plan to use the local provider.
$ git checkout tags/0.14.0-rc1
$ make install
This will install the the provider in ~/.terraform.d/plugins/registry.terraform.io/juju/juju/0.14.0/linux_amd64.
Update your configurations to use the local candidate:
terraform {
required_providers {
juju = {
source = "registry.terraform.io/juju/juju" # (uses local provider repository)
# source = "juju/juju" (uses the Hashicorp repository)
version = "~0.14.0"
LINKS:
NOTES:
- This release requires juju controller version 2.9.49 or later juju.
- This release uses juju client api code from the juju 3.5.1 release.
ENHANCEMENTS:
- Allow applications to specify charm resources as oci-image urls, in addition to revisions.
BUG FIXES:
- fix: bugs 535 and 539 only find storage for application being read by @hmlanigan in #557
- fix (application): do no panic on nil pointer by @hmlanigan in #563
- fix(constraints): ensure constraints are non-null by @jack-w-shaw in #556
- fix(storagedirective): fix storage directive validator by @anvial in #538
- fix(application): update resource example to use correct charm storage by @anvial in #533
