Charmcraft supports the development of operators using the Charmed Operator Framework . It enables developers to build, upload and release operators on Charmhub and collaboration through charm libraries.
New Release
Charmcraft 3.3.0 was just tagged and will shortly be released to the latest/candidate and 3.x/candidate channels . The team would appreciate any tests on this, if you find a regression or any new issue you can report it on GitHub.
The changelog can be found in the Charmcraft documentation.
Release Timeframe
The current plan is to release Charmcraft 3.3 to stable next Monday, 2025-01-27T00:00:00Z
Using Charmcraft
- Pack your Charmed Operator into a charm for distribution
Happy charming!
