Call for testing: Charmcraft 2.5.0
Charmcraft supports the development of operators using the Charmed Operator Framework . It enables developers to build, upload and release operators on Charmhub and collaboration through charm libraries.
New Release
Charmcraft 2.5.0 is currently building for release to the latest/candidate channel . The team would appreciate anyone who would like to test this. If you find a regression or any new issue, please report it at https://github.com/canonical/charmcraft/issues/new.
Changes
The major new features for this are:
Please view more about these changes in this earlier post.
Bug fixes
Known Issues:
If you find any issues, please raise them on our bug tracker
Under the hood
We have several major changes that shouldn’t affect the user experience right now, but prepare for much bigger changes coming soon! These include:
  • Early rockcraft-style extensions support
  • The Charmcraft snap is now based on core22
Using Charmcraft
Happy charming!
Couple things found while testing:
After 2.5.0 had a bug, 2.5.1 has been released to stable.
The 2.5.3 bugfix release is on its way to candidate.
Bugs fixed:
Full Changelog: Comparing 2.5.2...2.5.3 · canonical/charmcraft · GitHub
Changelog since 2.5.0: Comparing 2.5.0...2.5.3 · canonical/charmcraft · GitHub
Build progress can be seen on Launchpad
