Charmcraft supports the development of operators using the Charmed Operator Framework . It enables developers to build, upload and release operators on Charmhub and collaboration through charm libraries.
New Release
Charmcraft 2.4.0 was just released to latest/beta channel . The team would appreciate any tests on this, if you find a regression or any new issue you can report it on https://github.com/canonical/charmcraft/issues/new.
Changes
The major new features for this are:
- AlmaLinux base support
- Enable unstable builds with non-LTS Ubuntu releases
- Improved charm templates
We also have several bugfixes related to packing charms simultaneously.
Known Issues:
There are still some unfixed issues from the 2.3 series related to charmlibs and dependencies. We are tracking these on GitHub:
- Hashes in requirements.txt
- Packing failures with requirements.txt and pydeps
- Pinned dependencies not working as expected
These are targeted for a fix in 2.4.1, to be released soon.™
Using Charmcraft
- Pack your Charmed Operator into a charm for distribution
Happy charming!
