Charmcraft supports the development of operators using the Charmed Operator Framework . It enables developers to build, upload and release operators on Charmhub and collaboration through charm libraries.
New Release
Charmcraft 2.3.1 was just released to latest/candidate channel . The team would appreciate any tests on this, if you find a regression or any new issue you can report it on https://github.com/canonical/charmcraft/issues/new.
Changes
This is purely a bugfix release. A full list of changes can be found at https://github.com/canonical/charmcraft/releases/tag/2.3.1
Using Charmcraft
- Pack your Charmed Operator into a charm for distribution
Happy charming!
