Build dir not specified via command-line or environment
Hi all,
I’m trying to suppress this message build: Build dir not specified via command-line or environment; defaulting to /tmp/charm-builds. It’s appearing, even with JUJU_REPOSITORY set and i can’t find the correct env var to set in the docs.
Thanks!
That’s odd, it should be honoring JUJU_REPOSITORY. You could try setting CHARM_BUILD_DIR instead.
Yeah, I tried that too @cory_fu; not sure if it’s a bug or just not documented.
@joeborg JUJU_REPOSITORY='/path/to/juju/repository' charm build works as expected. How did you set JUJU_REPOSITORY environment variable?
