I’d like to have a local cloud that uses lxd VMs by default.
I’ve used juju bootstrap --constraints "mem=2G virt-type=virtual-machine" localhost lxd to boostrap with the lxd provider. From the docs my expectation was that for all future models on this cloud VM machines would be used:
If '--constraints' is used, its values will be set as the default
constraints for all future workload machines in the model, exactly as if
the constraints were set with `juju set-model-constraints`.
I could see the controller machine indeed was deployed as a VM. However after adding a model and deploying an application a container machine was added for the app.
peter@pirx ~ » lxc ls 1 ↵
| NAME | STATE | IPV4 | IPV6 | TYPE | SNAPSHOTS | LOCATION |
| juju-1687f6-0 | RUNNING | 240.22.0.194 (enp5s0) | | VIRTUAL-MACHINE | 0 | pirx |
| juju-c44708-0 | RUNNING | 240.22.0.223 (eth0) | | CONTAINER | 0 | pirx |
Am I misunderstanding the docs? Is there another way to have VMs by default?
juju version 3.5.0-genericlinux-amd64 lxd version 5.21.1 LTS
