Hi,
I’ve deployed several manual clouds for learning and each time Juju has required some manual intervention in order to get the bootstrap to succeed. Here’s my latest reproducer:
On my client:
wesley@ctrl:~$ snap list juju
Name Version Rev Tracking Publisher Notes
juju 3.3.0 25355 3.3/stable canonical✓ -
# ~/mcloud-test.yaml
clouds:
mcloud-test:
type: manual
endpoint: wesley@controller.cloud.lan
regions:
default: {}
Unencrypted ed25519 keypair stored at /home/wesley/.ssh/id_ed25519 with fingerprint:
SHA256:1PrhN2kIbUChhupYxSil2g9IyFppSeDH3hrfuvy5bxI wesley@ctrl
On controller.cloud.lan:
wesley@controller:~$ cat .ssh/authorized_keys
ssh-ed25519 AAAAC3NzaC1lZDI1NTE5AAAAIIy95UclpNmvDrQVzcogKMNXDvS47T+UigsNNOXMeiI/ wesley@ctrl
wesley@controller has sudo access with no password.
When I run the bootstrap, it fails:
wesley@ctrl:~$ juju add-cloud mcloud-test mcloud-test.yaml
Cloud "mcloud-test" successfully added to your local client.
wesley@ctrl:~$ juju bootstrap mcloud-test
ERROR initializing ubuntu user: subprocess encountered error code 255 (Failed to add the ECDSA host key for IP address '192.168.3.15' to the list of known hosts (/home/wesley/.ssh/known_hosts).
wesley@controller.cloud.lan: Permission denied (publickey).)
ERROR subprocess encountered error code 255 (Failed to add the ECDSA host key for IP address '192.168.3.15' to the list of known hosts (/home/wesley/.ssh/known_hosts).
wesley@ctrl:~$ ssh wesley@controller.cloud.lan
/var/log/auth.log on controller.cloud.lan indicates two successful login attempts from the ssh key with the above fingerprint. This looks like a missing permissions error on the client, but (I hope) one could be forgiven for mistaking it for a key authentication issue (Permission denied (publickey)).
Changing the cloud definition yaml to use the IP of controller.cloud.lan and signing in with ssh using the IP instead of the DNS name cleans up the permissions issues with known_hosts, but I’m still getting something similar:
ERROR initializing ubuntu user: subprocess encountered error code 255 (wesley@192.168.3.15: Permission denied (publickey).)
ERROR subprocess encountered error code 255 (wesley@192.168.3.15: Permission denied (publickey).)
Based on auth.log on controller Juju is trying to authenticate as ubuntu instead of wesley. Am I missing something obvious here or is this workflow broken?
