New to juju, i’m struggling to install the controller…The installation is failing and i did not find an indication on the origin of the issue…or probably i can’t interpret it.
When running juju bootsrrap command
.......(cut)
21:40:26 INFO juju.environs.bootstrap tools.go:83 found 1 packaged agent binaries
21:40:26 INFO cmd bootstrap.go:516 Starting new instance for initial controller
21:40:27 INFO cmd bootstrap.go:177 Launching controller instance(s) on inq-maas...
21:40:27 DEBUG juju.provider.maas environ.go:963 attempting to acquire node in zone "default"
21:40:28 DEBUG juju.cloudconfig.instancecfg instancecfg.go:981 Setting numa ctl preference to false
21:40:28 DEBUG juju.service discovery.go:63 discovered init system "systemd" from series "bionic"
21:40:28 DEBUG juju.provider.maas environ.go:1054 maas user data; 3516 bytes
21:40:33 DEBUG juju.provider.maas interfaces.go:365 interface "ens4" has no links
21:40:34 DEBUG juju.provider.maas environ.go:1100 started instance "hg6dfa"
21:40:34 INFO cmd bootstrap.go:274 - hg6dfa (arch=amd64 mem=4G cores=3)
21:40:34 INFO juju.environs.bootstrap bootstrap.go:899 newest version: 2.8.1
21:40:34 INFO juju.environs.bootstrap bootstrap.go:914 picked bootstrap agent binary version: 2.8.1
21:40:34 INFO cmd bootstrap.go:559 Installing Juju agent on bootstrap instance
21:40:39 INFO cmd bootstrap.go:690 Fetching Juju Dashboard 0.2.0
22:00:29 ERROR juju.cmd.juju.commands bootstrap.go:783 failed to bootstrap model: bootstrap instance started but did not change to Deployed state: instance "hg6dfa" is started but not deployed
......(cut)
I’m running :
Ubuntu 18.04.1 with MAAS version: 2.7.2
I’m getting this error when trying to install the juju controller on the MAAS
Hope someone could give an indication.
sorry for my english, this is the best i can deliver
