Charmed Blackbox Exporter
blackbox-exporter-k8s is a charm for Blackbox Exporter.
This Charmed Operator handles instantiation, scaling, configuration, and Day 2 operations specific to Blackbox Exporter.
This operator drives the Blackbox Exporter application, and it can be composed with other operators to deliver a complex application or service.
The charm imposes configurable resource limits on the workload, can be readily integrated with metrics providers such, and comes with built-in alert rules and dashboards for self-monitoring.
This charm is:
- intended to be used together with
prometheus-k8s
Navigation
| Level | Path | Navlink |
| 1 | Tutorials | Tutorials |
| 2 | monitor-ssl-certificates | Monitoring SSL Certificates |
| 1 | How To | How To |
| 2 | contributing | Contributing |
| 2 | integrating | Integrating |
| 2 | using | How to use the exporter |
| 1 | Reference | Reference |
| 2 | Actions | Actions |
| 2 | Configurations | Configurations |
| 2 | Libraries | Libraries |
| 1 | Explanation | Explanation |
| 2 | lma | Logging, Monitoring, and Alerting |
| 2 | what-is-observability | What is observability? |
Redirects
Mapping table
| Path | Location |
