Overview
The BIRD project aims to develop a dynamic IP routing daemon with full support of all modern routing protocols, easy to use configuration interface and powerful route filtering language, primarily targeted on (but not limited to) Linux and other UNIX-like systems and distributed under the GNU General Public License.
Currently, this charm is intended to validate BGP functionalities in various components of Charmed Kubernetes such as Calico or Kube-OVN.
Usage
To deploy this charm, simply run:
juju deploy bird --channel=edge
Configuration
AS Number
This charm allows you to change the BIRD Autonomous System Number (AS Number). You can change this value running:
juju config bird as-number=<as-number>
BGP Peers
It is possible to modify the BGP peers in the BIRD charm. To change them, simply run:
juju config bird bgp-peers="- address: 10.10.0.2
as-number: 64512
- address: 10.10.0.3
as-number: 64512
More information
- Find out more on BIRD website.
- Report bugs with this charm on Launchpad.
