azure-cloud-provider
Description
This subordinate charm manages the Cloud Controller and AzureDisk Storage controller components of Azure.
Usage
The charm requires azure credentials and connection information, which
can be provided either directly, via config, or via the azure-integration
relation to the Azure Integrator charm.
Deployment
The full process
juju deploy charmed-kubernetes
juju deploy azure-integrator --trust
juju deploy azure-cloud-provider
juju relate azure-cloud-provider:certificates easyrsa
juju relate azure-cloud-provider:kube-control kubernetes-control-plane
juju relate azure-cloud-provider:external-cloud-provider kubernetes-control-plane
juju relate azure-cloud-provider azure-integrator
## wait for the azure node controller daemonset to be running
## wait for the azure control manager deployment to be running
kubectl describe nodes |egrep "Taints:|Name:|Provider"
Details
- Requires a
charmed-kubernetesdeployment on a azure cloud launched by juju - Deploy the
azure-integratorcharm into the model using--trustso juju provided azure credentials - Deploy the
azure-cloud-providercharm in the model relating to the integrator and to charmed-kubernetes components - Once the model is active/idle, the cloud-provider charm will have successfully deployed the azure cloud controller and an azure-disk storage controller on each node in the kube-system namespace.
- Confirm the
ProviderIDis set on each node - Confirm the Storage Class
azure-csi-defaultis created
Contributing
Please see the Juju SDK docs for guidelines on enhancements to this charm following best practice guidelines, and CONTRIBUTING.md for developer guidance.
