This charm acts as a proxy to AWS and provides an interface to apply a certain set of changes via IAM roles, profiles, and tags to the instances of the applications that are related to this charm.
Usage
When on AWS, this charm can be deployed, granted trust via Juju to access AWS, and then related to an application that supports the interface. The set of permissions that the related application could request is documented in the interface’s Requires API documentation.
For example, Charmed Kubernetes has support for this, and can be deployed with the following bundle overlay:
applications:
aws-integrator:
charm: aws-integrator
num_units: 1
trust: true
relations:
- ['aws-integrator', 'kubernetes-control-plane']
- ['aws-integrator', 'kubernetes-worker']
Then deploy Charmed Kubernetes using this overlay:
juju deploy ccharmed-kubernetes --overlay ./k8s-aws-overlay.yaml --trust
Note: This trusts the AWS Integrator charm with the credentials used by Juju. You could instead provide alternate credentials via the `credentials` charm config option.
RDS
In addition to the integrator relation, this charm also provides a proxy to the
AWS Relational Database Service (RDS) for charms using the mysql interface.
Charms attached to the rds-mysql relation endpoint will have an RDS MySQL
database instance created for them and access information provided via the relation.
For example, if this was deployed alongside the Mediawiki charm, it could provide the database for backing the wiki:
applications:
aws-integrator:
num_units: 1
trust: true
mediawiki:
charm: mediawiki
num_units; 1
relations:
- ['aws-integrator:rds-mysql', 'mediawiki:db']
Permissions Requirements
The credentials given to the charm must include the following access rights:
| EC2 |
| AssociateIamInstanceProfile |
| CreateTags |
| DescribeInstances |
| IAM |
| AddRoleToInstanceProfile |
| AttachRolePolicy |
| CreateInstanceProfile |
| CreatePolicy |
| CreateRole |
| DeleteInstanceProfile |
| DeletePolicy |
| DeleteRole |
| DetachRolePolicy |
| ListAttachedRolePolicies |
| ListInstanceProfiles |
| ListPolicies |
| ListRoles |
| RemoveRoleFromInstanceProfile |
| CreatePolicyVersion |
| ListPolicyVersions |
| GetPolicyVersion |
| DeletePolicyVersion |
| SetDefaultPolicyVersion |
| GetPolicy |
| STS |
| GetCallerIdentity |
| RDS |
| DescribeDBInstances |
| CreateDBInstance |
| DeleteDBInstance |
| DeleteDBInstanceAutomatedBackup |
Note that these may be different from the permissions that Juju requires to operate.
Resource Usage Note
By relating to this charm, other charms can directly allocate resources, such as EBS volumes and ELBs, which could lead to cloud charges and count against quotas. Because these resources are not managed by Juju, they will not be automatically deleted when the models or applications are destroyed, nor will they show up in Juju’s status or GUI. It is therefore up to the operator to manually delete these resources when they are no longer needed, using the AWS console or API.
Examples
Following are some examples using AWS integration with Charmed Kubernetes.
Creating a pod with an EBS-backed volume
This script creates a busybox pod with a persistent volume claim backed by AWS’s Elastic Block Storage.
#!/bin/bash
# create a storage class using the `kubernetes.io/aws-ebs` provisioner
kubectl create -f - <<EOY
apiVersion: storage.k8s.io/v1
kind: StorageClass
metadata:
provisioner: kubernetes.io/aws-ebs
parameters:
type: gp2
EOY
# create a persistent volume claim using that storage class
kind: PersistentVolumeClaim
apiVersion: v1
metadata:
spec:
accessModes:
- ReadWriteOnce
resources:
requests:
storage: 100Mi
storageClassName: ebs-1
EOY
# create the busybox pod with a volume using that PVC:
apiVersion: v1
kind: Pod
metadata:
namespace: default
spec:
containers:
- image: busybox
command:
- sleep
- "3600"
imagePullPolicy: IfNotPresent
volumeMounts:
- mountPath: "/pv"
restartPolicy: Always
volumes:
- name: testvolume
persistentVolumeClaim:
claimName: testclaim
EOY
Creating a service with an AWS load-balancer
The following script starts the hello-world pod behind an AWS Elastic Load Balancer.
kubectl create deployment hello-world --image=gcr.io/google-samples/node-hello:1.0
kubectl scale deployment hello-world --replicas=5
kubectl expose deployment hello-world --type=LoadBalancer --name=hello --port=8080
watch kubectl get svc hello -o wide
