aws-cloud-provider
Description
This subordinate charm manages the cloud controller-manager components for aws.
Requirements
- these polices are defined as prerequisites
- the primary unit, the aws-integrator application must have access to create IAM Policies
Usage
The charm requires aws credentials and connection information, which
can be provided the aws-integration relation to the AWS Integrator charm.
Deployment
Quickstart
The AWS Cloud Provider subordinate charm can be deployed alongside Charmed Kubernetes using the overlay provided in the Charmed Kubernetes bundle repository:
juju deploy charmed-kubernetes --overlay aws-cloud-overlay.yaml
The full process
juju deploy aws-integrator --trust
juju deploy aws-cloud-provider
juju relate aws-cloud-provider:certificates easyrsa
juju relate aws-cloud-provider:kube-control kubernetes-control-plane
juju relate aws-cloud-provider:external-cloud-provider kubernetes-control-plane
juju relate aws-cloud-provider:aws-integration aws-integrator
## wait for the aws controller daemonset to be running
# the cloud-controller will set the node's ProviderID
kubectl describe nodes |egrep "Taints:|Name:|Provider"
Storage
- to access Native AWS storage, see the AWS Storage charm.
Details
- Requires a
charmed-kubernetesdeployment on a aws cloud launched by juju with theallow-privilegedflag enabled. - Deploy the
aws-integratorcharm into the model using--trustso juju provided vsphere credentials - Deploy the
aws-cloud-providercharm in the model relating to the integrator and to charmed-kubernetes components - Once the model is active/idle, the cloud-provider charm will have successfully deployed the aws controller-manager in the kube-system namespace
- Taint the existing nodes so the controller will apply the correct provider id to those nodes.
- Confirm the
ProviderIDis set on each node - For the controller to operate, the aws-integrator charm will apply the appropriate IAM policies and standardize the cluster-tag
- the Kubernetes-Worker and Kuberenetes-Control-Plane charms start their binaries with
--external-providerrather than the in-tree switch--cloud-provider=awswhich has been removed starting in kubernetes 1.27
Contributing
Please see the Juju SDK docs for guidelines on enhancements to this charm following best practice guidelines, and CONTRIBUTING.md for developer guidance.
