Is there a workaround to telling Juju to use a predefined security group on an AWS bootstrap? Due to permissions constraints/etc. our automation needs to work with predefined security groups that are made manually.
@manadart I am just starting to use AWS with juju for the first time… if I was super paranoid about security and wanted to lock down or start with the more hardened VPC… does that security group you mentioned start as restricted JUST to what it i needs to talk to JUJU controller and grab resources like apt install npm install etc…? or is everything pretty wide open and I should craft my own VPC for prod which is restricted from the jump… and juju will handle what it needs to do to install…
EDIT:
I did some googling and found what looks to be a terrific primer on AWS VPCs and basic networking from 10K ft… so I plan next to create a Development and Production VPC… each will look sort of like this diagram
What I am researching next is… how do I constrain some of my machines to 1 subnet… and another set of machines to the other subnet. guessing I utilize juju spaces somehow … so researching that now
