Atelier: Rebuilding state from a live deployment
(Re)construct Terraform state from a live deployment by pointing Atelier at the upstream module that manages it.
This document is part of a series about Atelier. If you are new to Atelier, start with Introducing Atelier.
Lost your Terraform state, or never had one to begin with? With atelier import, you can reconstruct it from a live deployment by pointing Atelier at the upstream module that manages it.
What atelier import does
atelier import juju clones the upstream module, writes an Atelier wrapper, discovers live resources via terraform query, matches them to the module’s resource addresses, and runs terraform import for each match. The result is a wrapper directory whose Terraform state reflects your running infrastructure, ready to manage with normal Atelier operations.
Use cases
  1. Bundle to Terraform migration. A COS Lite deployment originally deployed via a Juju bundle is now managed through Terraform, but the bundle’s resource graph and the Terraform module’s resource graph don’t map 1:1.
  2. Lost state file. You deployed COS Lite with Terraform, deleted or lost the terraform.tfstate, and need to continue managing the existing deployment.
To avoid data loss, juju_application resources must not show replace or create actions in the Terraform plan.
Importing a COS deployment
Given a running Canonical Observability Stack (COS) deployment, note the model UUID from juju models, then run:
mkdir import-target && cd import-target
atelier import juju \
    --source https://github.com/canonical/observability-stack.git \
    --module terraform/cos \
    --ref track/3.0 \
    --query-var model_uuid=2af837d8-f470-488e-84cb-c588a39732d8 \
    --preset cos-vars
The --source, --module, and --ref flags tell Atelier which upstream module to clone. The --query-var input (here, model_uuid) is required by the Juju provider’s query engine. The --var or --preset flags supply variable values the module needs.
After the import
Atelier queries the live deployment and reports what it matched. For COS, 98/118 resources are automatically importable:
Matched 98 resource(s):
  module.cos.module.catalogue.juju_application.catalogue  (import ID: 2af837d8-…:catalogue)
  module.cos.module.grafana.juju_application.grafana      (import ID: 2af837d8-…:grafana)
  module.cos.juju_integration.ingress["loki"]             (import ID: 2af837d8-…:traefik:ingress:loki:ingress)
Some module resources have zero or ambiguous live matches and must be imported manually. Live resources not declared by the module are left alone. From this point forward, you manage the deployment with normal Atelier operations. Running atelier in the wrapper directory opens the TUI with the imported state loaded:
Module: cos@track/3.0  ✓ valid  ⚠ 6 check warning(s)
The variables pane shows the module’s inputs, and the plan view confirms the import has a small delta against the live deployment:
Plan: 6 to add, 7 to change, 0 to destroy.  |  State: 111 resource(s) across 25 modules
The six resources to add are juju_access_secret objects that terraform query cannot resolve (zero or ambiguous matches). The seven changes are attribute drift, mostly where the module’s defaults diverge slightly from the live state. Neither category represents a real infrastructure change, which is exactly what you want to see after an import: the state is close enough that a plan is a formality, not a warning.
Next steps
With state imported, you can use Atelier like any other wrapper: edit variables in the TUI, plan to check the diff, apply to converge, or bump the module ref to upgrade the deployment. The wrapper is a normal Atelier wrapper; the import just gave it a head start.
