Deploy the aproxy subordinate charm
The aproxy subordinate charm provides proxy functionality that can be attached to a principal charm. As a subordinate charm, it enhances existing applications by adding proxy configuration management and integration without being deployed as a standalone service.
In this tutorial, you will deploy the aproxy subordinate charm in a Juju model, relate it to a principal charm, and verify that it is correctly integrated and running.
What you will do
In this tutorial, you will:
- Set up a Juju model for testing.
- Deploy a principal charm that aproxy can relate to.
- Deploy the aproxy subordinate charm and relate it to the principal charm.
- Verify that the deployment was successful.
- Perform a simple configuration test.
- Tear down your environment.
Requirements
Before starting, ensure you have the following:
- A working station (e.g., a laptop) with amd64 architecture.
- Juju 3 installed and bootstrapped to a LXD controller. You can accomplish this process by using a Multipass VM as outlined in this guide: Set up / Tear down your test environment.
Set up the tutorial model
First, create a new Juju model named aproxy-tutorial. This model will isolate the tutorial environment from your other deployments.
juju add-model aproxy-tutorial
You can confirm that the model has been created by running:
juju models
Deploy the principal charm
Since aproxy is a subordinate charm, it must be related to a principal charm. In this example, we will use the Ubuntu charm as the primary application to demonstrate how aproxy integrates with another service.
Deploy the Ubuntu charm:
juju deploy ubuntu
Wait until the deployment is complete:
juju status --watch 1s
When the application is active and ready, the output should look similar to:
ubuntu 24.04 active 1 ubuntu latest/stable 26 no
Now deploy the aproxy charm with the target proxy address and proxy port. In this tutorial, we will use 127.0.0.1:80.
juju deploy aproxy --config proxy-address="127.0.0.1:80"
Because it is a subordinate charm, it will not create its own unit until it is integrated to a principal charm.
Integrate aproxy to the principal charm
Next, integrate the aproxy subordinate charm to the Ubuntu application. This establishes the connection that allows aproxy to intercept outbound TCP traffic from the Ubuntu charm.
juju integrate ubuntu aproxy
Once the relation is established, Juju will automatically attach aproxy to the Ubuntu unit.
Check the deployment was successful
Verify that both charms are deployed and related correctly:
juju status
The output should be similar to the following:
Model Controller Cloud/Region Version
aproxy-tutorial lxd localhost 3.4.1
aproxy active 1 aproxy latest/stable 1 no Service ready on target proxy 127.0.0.1:80
ubuntu/0* active idle 0 10.152.184.228
aproxy/0* active idle 10.152.184.228 Service ready on target proxy 127.0.0.1:80
You should see both applications in an active state, with aproxy listed as a subordinate unit to the Ubuntu charm.
Run a configuration test
To confirm that the charm is functioning properly, run configuration change on aproxy.
Let’s set the intercept-ports to be 80:
juju config aproxy intercept-ports=80
Then verify that the configuration has been applied:
juju config aproxy
application: aproxy
application-config:
trust:
default: false
description: Does this application have access to trusted credentials
source: default
type: bool
value: false
charm: aproxy
settings:
exclude-addresses-from-proxy:
default: 127.0.0.1
description: Comma-separated list of IP or hostname addresses that should bypass
the proxy.
source: default
type: string
value: 127.0.0.1
intercept-ports:
default: 80,443
description: |
Comma-separated list of ports to intercept and forward through the proxy.
Support:
- Single port e.g., 80
- List of comma-separated ports e.g., 80,443
- Range (both sides included) e.g., 1024-2048
- List of ranges e.g. 80-90,1024-2048
- Keyword "ALL" which corresponds to the range 1-65536
source: default
type: string
value: 80
proxy-address:
description: |
Configures the target proxy IP address and port for traffic forwarding.
For example: "1.2.3.4:8888" or "1.2.3.4".
If no proxy is specified, the default proxy is the principal charm's juju-https-proxy or juju-http-proxy relation data.
If no port is specified, the default port value of 80 will be used.
source: user
type: string
value: 127.0.0.1:80
Run a connection test
To confirm that aproxy is forwarding properly, make an outbound TCP connection on the principal charm.
For example, let’s curl cloud-images.ubuntu.com from inside ubuntu/0 unit:
juju ssh ubuntu/0
curl -v cloud-images.ubuntu.com
If successful, the output should be similar to the following:
* Host cloud-images.ubuntu.com:80 was resolved.
* IPv6: 2620:2d:4000:1::17, 2620:2d:4000:1::1a
* IPv4: 185.125.190.40, 185.125.190.37
* Trying 185.125.190.40:80...
* Connected to cloud-images.ubuntu.com (185.125.190.40) port 80
> GET / HTTP/1.1
> Host: cloud-images.ubuntu.com
> User-Agent: curl/8.5.0
> Accept: */*
< HTTP/1.1 200 OK
< Transfer-Encoding: chunked
< Connection: close
< Content-Type: text/html;charset=UTF-8
< Date: Tue, 14 Oct 2025 08:43:00 GMT
< Server: Apache/2.4.29 (Ubuntu)
< Vary: Accept-Encoding
< Via: 1.1 juju-9d5023-prod-ps6-internal-proxy-13 (squid/5.9)
< X-Cache: MISS from juju-9d5023-prod-ps6-internal-proxy-13
< X-Cache-Lookup: MISS from juju-9d5023-prod-ps6-internal-proxy-13:3128
Then verify that aproxy is intercepting and forwarding the traffic to target proxy:
sudo snap logs aproxy.aproxy -f
Expected output:
2025-10-13T14:18:16Z aproxy.aproxy[16156]: 2025/10/13 14:18:16 INFO start listening on :8443
2025-10-13T14:18:16Z aproxy.aproxy[16156]: 2025/10/13 14:18:16 INFO start forwarding to proxy 127.0.0.1:80
2025-10-14T08:43:00Z aproxy.aproxy[16156]: 2025/10/14 08:43:00 INFO relay HTTP connection to proxy src=10.142.134.228:41826 original_dst=185.125.190.40:80 host=cloud-images.ubuntu.com:80
Tear down the environment
Congratulations! ![]()
You have successfully deployed the aproxy subordinate charm, related it to a primary application, and verified that it works as expected.
When you’re done with the tutorial, clean up your environment to free resources:
juju destroy-model aproxy-tutorial --destroy-storage --force --no-prompt
If you used a Multipass VM for this tutorial and no longer need it, you can remove it with:
multipass delete --purge my-juju-vm
Next steps
Visit the aproxy charm documentation for advanced usage and configuration options.
