Aproxy operator documentation - how to upgrade
How to upgrade
To upgrade the aproxy charm, use the juju refresh command. Since aproxy does not manage any persistent data or databases, there are no backup or migration steps required before upgrading.
Before you begin
Before performing an upgrade, ensure that your Juju model is in a healthy state:
juju status
Confirm that all units are active and idle.
Refresh to the latest revision
To upgrade aproxy to the latest revision from Charmhub:
juju refresh aproxy
This command will pull and apply the most recent revision of the aproxy charm from the same channel it was originally deployed from.
Verify the upgrade
After the refresh completes, confirm that the charm and its units are active:
juju status aproxy
The application status should display as:
Active   aproxy/0  ...
