How to configure
This guide explains how to configure the aproxy charm to control how traffic is intercepted and forwarded through a target proxy.
Overview
The aproxy charm provides several configuration options that control how outbound traffic is handled, which addresses bypass the proxy, and which ports are intercepted.
These configurations can be applied:
- During deployment (using
juju deploy --config), or - After deployment (using
juju config).
Example:
juju deploy aproxy --config proxy-address="1.2.3.4:8080"
Configuration options
There are three configuration options available: proxy-address, exclude-addresses-from-proxy, and intercept-ports.
proxy-address
Specifies the target proxy IP address and port for traffic forwarding.
Format:
"IP:PORT"or"IP" -
Example:
1.2.3.4:88881.2.3.4(defaults to port80)
If no value is provided:
- The charm will attempt to use the
juju-https-proxyorjuju-http-proxyJuju model configuration data. - If the proxy relation is unavailable, the charm will remain in a
BlockedStatusuntil a valid configuration is provided.
Usage Example:
juju config aproxy proxy-address="10.0.0.5:8080"
Comma-separated list of IP addresses or hostnames that should bypass the proxy. When this option is set, nftables rules are updated so that outbound traffic to the specified addresses is exempted from proxy interception.
- Default:
"127.0.0.1" - Useful for excluding local or internal addresses that should bypass the proxy.
Usage example:
juju config aproxy exclude-addresses-from-proxy="127.0.0.1,example.local"
intercept-ports
Defines which ports are intercepted and forwarded through the proxy.
This field supports flexible input patterns:
| Type | Example | Description |
| Single port | 80 |
Intercepts traffic on port 80 |
| Multiple ports | 80,443,8080 |
Intercepts several ports |
| Range | 1024-2048 |
Intercepts all ports from 1024 to 2048 |
| Multiple ranges | 80-90,1024-2048 |
Combines ranges and specific ports |
| All ports | ALL |
Intercepts all TCP ports (1–65536) |
- Default:
"80,443"
Usage example:
juju config aproxy intercept-ports="80,443,8080-8090"
Example: full configuration
Below is a sample configuration command that sets all options explicitly:
juju config aproxy \
proxy-address="10.10.10.5:8080" \
exclude-addresses-from-proxy="127.0.0.1,10.10.10.0/24" \
After applying the configuration, the charm will:
- Validate the provided settings.
- Configure the Aproxy snap.
- Apply nftables rules to redirect outbound traffic as specified.
- Report an
ActiveStatusonce setup completes successfully.
Troubleshoot
If the configuration is invalid or incomplete, the charm may enter a BlockedStatus with an error message such as:
BlockedStatus: Invalid charm configuration: missing proxy address
Common fixes:
- Verify that the
proxy-addressandexclude-addresses-from-proxyconsist of valid IP or hostname. - Ensure that the
intercept-portsfield uses valid syntax (no spaces, only commas and dashes). - Check that your model configuration data is correctly set if you’re relying on
juju-http-proxyorjuju-https-proxy.
