How to back up and restore
The aproxy subordinate charm does not maintain application data or databases of its own. Since the charm is stateless apart from configuration, there is no persistent data that needs a traditional backup/restore procedure.
Back up
To preserve the state of the deployment, back up the following:
Charm configuration
Run:
juju config aproxySave the output, including:
proxy-addressexclude-addresses-from-proxyintercept-ports
System snapshot (optional)
If required for compliance, you can also back up system-level state:
- List of installed snaps (
snap list) - nftables configuration (
sudo nft list ruleset)
Restore
To restore the charm to its previous state:
Redeploy the charm
juju deploy aproxy --config proxy-address=<saved-address> \ --config exclude-addresses-from-proxy=<saved-exclude-addresses-from-proxy> \ --config intercept-ports=<saved-ports> -
(Optional) Reapply system snapshot
If you captured nftables or snap state for compliance, restore them with:
sudo snap install aproxy --edge sudo nft -f <saved-ruleset-file>
In most cases, reapplying the saved Juju configuration is sufficient. The charm will automatically reinstall the snap and regenerate nftables rules.
