Hi,
This is about ProxmoxVE v6.3.6, MaaS 2.9.2, Juju 2.9rc10. I have a deployment on the technology stack with Proxmox VE (6.3.6), MaaS (2.9.2) and Juju (2.9rc10).
I have the problem, that when deploying an application, then it does not respect the binding and the application ends-up in the wrong subnet. MaaS is configured as DHCP server on both subnets.
- MaaS region controllers are on subnet 10.1.1.0/24
- MaaS rack controllers are on both subnets 10.1.1.0/24 and 10.1.20.0/24
- the VMs I deploy the applications to are on both subnets 10.1.1.0/24 and 10.1.20.0/24
- MaaS has 3 availability zones: default, Production, Infrastructure
MaaS availability zones (not used in Juju?), Subnets and machine config Note: the Juju controller(s) are deployed to AZ Infrastructure, the application VMs to Production.
Following are the spaces and the subnets configured in Juju. They correspond to what is available in MaaS:
juju spaces / juju subnets
yaml
- id: "0"
subnets: {}
- id: "1"
subnets:
10.1.20.0/24:
type: ipv4
provider-id: "2"
status: in-use
zones: []
- id: "2"
subnets:
10.1.1.0/24:
type: ipv4
provider-id: "1"
status: in-use
zones: []
For reasons of simplicity, I want to deploy a null application to the default model. Before doing that, I’ve set the default-space of the model-config to computing space.
juju model-config default-space=computing
juju deploy cs:~katharostech/null-8 --bind computing
Finally, I get the following status of the null application:
juju status null
yaml
model:
type: iaas
controller: maas-controller
cloud: mysuper-cloud
region: default
version: 2.9-rc10
model-status:
current: available
since: 15 Apr 2021 00:16:40+02:00
sla: unsupported
machines:
"0":
juju-status:
current: started
since: 15 Apr 2021 00:28:34+02:00
version: 2.9-rc10
hostname: my-proxmox-vm
dns-name: 10.1.1.92
ip-addresses:
- 10.1.1.92
- 10.1.20.41
instance-id: swqkyb
display-name: my-proxmox-vm
machine-status:
current: running
message: Deployed
since: 15 Apr 2021 00:27:59+02:00
modification-status:
current: idle
since: 15 Apr 2021 00:21:06+02:00
series: focal
network-interfaces:
ens18:
ip-addresses:
- 10.1.1.92
mac-address: 6a:2a:f1:ee:25:7f
gateway: 10.1.1.254
space: infrastructure
is-up: true
ens19:
ip-addresses:
- 10.1.20.41
mac-address: c6:76:4e:42:3d:d7
space: computing
is-up: true
constraints: arch=amd64 mem=3072M
hardware: arch=amd64 cores=2 mem=4096M tags=virtual,master availability-zone=Production
applications:
"null":
charm: cs:~katharostech/null-8
series: focal
os: ubuntu
charm-origin: charmstore
charm-name: "null"
charm-rev: 8
charm-channel: stable
charm-version: fc2c0ed-dirty
charm-profile: juju-default-null-8
exposed: false
application-status:
current: active
since: 15 Apr 2021 00:28:42+02:00
units:
null/0:
workload-status:
current: active
juju-status:
current: idle
since: 15 Apr 2021 00:28:44+02:00
version: 2.9-rc10
leader: true
machine: "0"
public-address: 10.1.1.92
endpoint-bindings:
"": computing
storage: {}
controller:
timestamp: 08:08:42+02:00
I would expect the application to be deployed to subnet 10.1.20.0/24 with a public-address in this subnet space. I have tried many things now but got stuck on this. Any help is highly appreciated.
Cheers
