Overview
This charm provides the Aodh Alarming service for an OpenStack Cloud.
Important: This documentation supports version 3.x of the Juju client.
See the OpenStack Charm
guide if you are using the 2.9.x client.
Usage
Aodh relies on services from the mongodb, rabbitmq-server and keystone charms:
juju deploy aodh
juju deploy keystone
juju deploy mysql
juju deploy rabbitmq-server
juju integrate aodh rabbitmq-server
juju integrate aodh mysql
juju integrate aodh keystone
Policy Overrides
Policy overrides is an advanced feature that allows an operator to override the default policy of an OpenStack service. The policies that the service supports, the defaults it implements in its code, and the defaults that a charm may include should all be clearly understood before proceeding.
Caution: It is possible to break the system (for tenants and other services) if policies are incorrectly applied to the service.
Policy statements are placed in a YAML file. This file (or files) is then (ZIP) compressed into a single file and used as an application resource. The override is then enabled via a Boolean charm option.
Here are the essential commands (filenames are arbitrary):
zip overrides.zip override-file.yaml
juju attach-resource aodh policyd-override=overrides.zip
juju config aodh use-policyd-override=true
See appendix Policy Overrides in the OpenStack Charms Deployment Guide for a thorough treatment of this feature.
Bugs
Please report bugs on Launchpad.
For general questions please refer to the OpenStack Charm Guide.
Navigation
| Level | Path | Navlink |
| 1 | Home |
