Hello ,
I have deployed my charm on my local controller and the status is showing as error , Then I have made some changes on my hooks file to solve that error , what’s the ideal way to re-deploy this charm on the same controller without having to destroy it again and re-deploy everything ?
I run the same deploy command and the status still showing as error , so I thought it might need to be destroyed every time if i made any changes…
please advice on above
thank you
