This page offers more in-depth information on LXD itself. To learn how to set up LXD with Juju see Using LXD with Juju.
The topics presented here are:
- Useful LXD client commands
- Using the LXD snap
- LXD logs
- Further LXD help and reading
There are many client commands available. Some common ones, including those covered above, are given below.
| client commands | meaning |
lxc launch |
creates an LXD container |
lxc list |
lists all LXD containers |
lxc delete |
deletes an LXD container |
lxc remote list |
lists remotes |
lxc info |
displays status of localhost |
lxc info <container> |
displays status of container |
lxc config show <container> |
displays configuration of container |
lxc image info <alias or fingerprint> |
displays status of image |
lxc exec <container> <executable> |
runs program on container |
lxc exec <container> /bin/bash |
spawns shell on container |
lxc file pull <container></path/to/file> . |
copies file from container |
lxc file push </path/to/file> <container>/ |
copies file to container |
lxc stop <container> |
stops container |
lxc image list |
lists cached images |
lxc image alias delete <alias> |
deletes image alias |
lxc image alias create <alias> <fingerprint> |
creates image alias |
lxc cluster list |
lists cluster nodes |
lxc cluster show <container> |
displays configuration of a cluster node |
Using the LXD snap
The LXD project will soon be moving from the APT installation method (Debian package) to installing via a snap. Some users may want to opt in early, before building their infrastructure, as moving to the snap entails a migration of containers. The LXD snap is very well tested (as is the included migration tool).
First ensure that snapd is installed:
sudo apt install snapd
On Ubuntu 14.04 LTS (Trusty), installing snapd will bring in a new kernel (4.4.0 series) as a dependency. You will then need to reboot. Attempting to install a snap without doing so will result in failure.
Now install the LXD snap:
sudo snap install lxd
If LXD is already installed via APT and there are no existing containers under the current installation then simply remove the software:
sudo apt purge liblxc1 lxcfs lxd lxd-client
Migrating containers
If containers do exist under the old system the lxd.migrate utility should be used to migrate them so that they can be managed by the snap binaries. Once the migration is complete, you will be prompted to have the old software removed.
Start the migration tool by running:
sudo lxd.migrate
LXD logs
LXD itself logs to /var/log/lxd/lxd.log and Juju machines created via the LXD local provider log to /var/log/lxd/juju-UUID-machine-ID. However, the standard way to view logs is with the debug-log command (see the Juju logs page for details).
For LXD snap users, the log directory is located at /var/snap/lxd/common/lxd/logs.
Further help and reading
See lxc --help for more information on LXD client usage and lxd --help for assistance with the daemon. See upstream documentation for LXD configuration.
