Hi Boss
Thank you for ur mail boss
I did this below command not able to see in openstack dashboard in hypervisor list 68 TB volume and its taking another disk sdb
juju add-unit ceph-osd --to HP-storage
juju config ceph-osd osd-devices="/dev/sdb"
Hi Boss
You wonât necessarily see the storage on the Openstack Dashboard.
Try this trick so that nova writes ephemeral instances into ceph too. The storage should report on the openstack dashboard then
juju config nova-compute libvirt-image-backend=rbd
This is what my yaml looks like:
nova-compute:
annotations:
gui-x: '190'
gui-y: '890'
charm: cs:nova-compute
num_units: 6
options:
customize-failure-domain: true
libvirt-image-backend: rbd
rbd-pool: cinder-ceph
config-flags: default_ephemeral_format=ext4
enable-live-migration: true
enable-resize: true
migration-auth-type: ssh
openstack-origin: *openstack-origin
bindings:
"": admin-network
to:
- '0'
- '1'
- '2'
- '3'
- '4'
- '5'
In you previous post. Your juju status shows ceph-osd has no block devices configured.
Is this still the case ?
Dear Sirâs
After adding the nova compute to Hp-storage now volume size increased to another Hp-01 hard disk size 120 its 979 GB
