I created a manual cloud and made the bootstrap.
My environment is composed by machine with juju client connected to internet through a proxy and a controller machine without any internet connection, plus other machine without internet connection too.
I am following [Installing Charmed Kubernetes on Existing Machines | Ubuntu] (https://ubuntu.com/kubernetes/docs/install-existing) guide but I stuck at this step:
juju add-machine ssh:user@kube1
where the logs stay blocked here:
15:30:14 INFO juju.cmd supercommand.go:56 running juju [3.5.4 31b4b0914740b84ad8166993635ac797a44276de gc go1.23.1]
15:30:14 DEBUG juju.cmd supercommand.go:57 args: []string{"/snap/juju/28520/bin/juju", "add-machine", "ssh:user@kube1", "--debug", "--verbose"}
15:30:14 INFO juju.juju api.go:86 connecting to API addresses: [controller.localdomain :17070 10.112.112.133:17070]
15:30:14 DEBUG juju.api apiclient.go:1036 successfully dialed "wss://controller.localdomain :17070/model/f8d948f4-1958-443b-8c87-07740f1f087c/api"
15:30:14 INFO juju.api apiclient.go:938 cannot resolve "controller": lookup controller.localdomain : operation was canceled
15:30:14 INFO juju.api apiclient.go:571 connection established to "wss://controller.localdomain :17070/model/f8d948f4-1958-443b-8c87-07740f1f087c/api"
15:30:14 INFO juju.cmd.juju.machine add.go:318 load config
15:30:15 DEBUG juju.api apiclient.go:689 looked up controller.localdomain -> [10.112.112.133]
In the meanwhile the controller logs report this connectivity error but is normal because there is no internet connection:
e8f59093-b9ab-438c-84ae-3a372e1f7ac4: machine-0 2024-10-10 15:29:49 WARNING juju.environs.simplestreams datasource.go:212 Got error requesting "https://streams.canonical.com/juju/tools/streams/v1/index2.sjson": Get "https://streams.canonical.com/juju/tools/streams/v1/index2.sjson": dial tcp: lookup streams.canonical.com on 127.0.0.53:53: no such host
e8f59093-b9ab-438c-84ae-3a372e1f7ac4: machine-0 2024-10-10 15:29:50 WARNING juju.environs.simplestreams datasource.go:212 Got error requesting "https://streams.canonical.com/juju/tools/streams/v1/index2.sjson": Get "https://streams.canonical.com/juju/tools/streams/v1/index2.sjson": dial tcp: lookup streams.canonical.com on 127.0.0.53:53: no such host
e8f59093-b9ab-438c-84ae-3a372e1f7ac4: machine-0 2024-10-10 15:29:52 WARNING juju.environs.simplestreams datasource.go:212 Got error requesting "https://streams.canonical.com/juju/tools/streams/v1/index2.sjson": Get "https://streams.canonical.com/juju/tools/streams/v1/index2.sjson": dial tcp: lookup streams.canonical.com on 127.0.0.53:53: no such host
e8f59093-b9ab-438c-84ae-3a372e1f7ac4: machine-0 2024-10-10 15:29:52 ERROR juju.worker.dependency engine.go:695 "tools-version-checker" manifold worker returned unexpected error: cannot update agent binaries information: cannot get latest version: cannot find available agent binaries: cannot read index data, attempt count exceeded: cannot access URL "https://streams.canonical.com/juju/tools/streams/v1/index2.sjson": Get "https://streams.canonical.com/juju/tools/streams/v1/index2.sjson": dial tcp: lookup streams.canonical.com on 127.0.0.53:53: no such host
what step I miss?
