A few days ago, our dear @dnplas asked us in our Observability Practice channel in Matrix:
Hi folks! Happy Tuesday! Is there any recommendation for placing the
MetricsEdnpointProviderconstructor in the init method? Say before or after theself.framework.observe(...)calls?
After that there was an interesting exchange about how to organise the code within charm.py, but more specifically within the charm class itself.
About how to organise the code, there are as many opinions as developers. This is just the way I like to organise the code inside the charm file because I believe it is clean, and helps your future you (or another team member) to understand the code.
Table of Contents
- Before the
__init__method - The
__init__method - Inside the
__init__method - After the
__init__method - Final notes
Before the __init__ method
As a regular (executable) python file, charm.py will have at the top:
- The shebang
- A Copyright notice
- A small docstring
- All the imports
- Constants definition
loggerinstantiation- Utility functions that are not part of the charm class.
For instance:
#!/usr/bin/env python3
# Copyright 2020 Canonical Ltd.
# See LICENSE file for licensing details.
"""A Juju charm for Prometheus on Kubernetes."""
import hashlib
import logging
import re
import socket
import subprocess
from pathlib import Path
from typing import Dict, Optional, cast
from urllib.parse import urlparse
import yaml
from charms.alertmanager_k8s.v1.alertmanager_dispatch import AlertmanagerConsumer
KEY_PATH = f"{PROMETHEUS_DIR}/server.key"
CERT_PATH = f"{PROMETHEUS_DIR}/server.cert"
CA_CERT_PATH = f"{PROMETHEUS_DIR}/ca.cert"
WEB_CONFIG_PATH = f"{PROMETHEUS_DIR}/prometheus-web-config.yml"
logger = logging.getLogger(__name__)
def sha256(hashable) -> str:
"""Use instead of the builtin hash() for repeatable values."""
if isinstance(hashable, str):
hashable = hashable.encode("utf-8")
return hashlib.sha256(hashable).hexdigest()
The __init__ method
When writing a Charmed Operator, the __init__ method is really important since you define there the libraries the charm uses, and how the charm will behave when receives an event.
Despite of the fact you can place the __init__ method wherever you want inside the class, it is a good practice to place its definition at the top of it so it is the first thing you see at glance.
Inside the __init__ method
Inside the __init__ method a good way to have everything tided up is to instantiate the libraries first, and then define the events handler registration:
class MimirCoordinatorK8SOperatorCharm(ops.CharmBase):
"""The Mimir Coordinator charm class."""
def __init__(self, *args: Any):
super().__init__(*args)
self._nginx_container = self.unit.get_container("nginx")
self.server_cert = CertHandler(
charm=self,
key="mimir-server-cert",
sans=[self.hostname],
self.s3_requirer = S3Requirer(self, S3_RELATION_NAME, BUCKET_NAME)
# === EVENT HANDLER REGISTRATION === #
self.framework.observe(self.on.config_changed, self._on_config_changed)
self.framework.observe(self.on.collect_unit_status, self._on_collect_status)
self.framework.observe(self.on.nginx_pebble_ready, self._on_nginx_pebble_ready)
self.on.mimir_cluster_relation_changed, self._on_mimir_cluster_changed
After the __init__ method
Now it is time to write the methods and properties of the class. For that I believe the following order will provide a clean organisation of the charm class:
- Event handler methods
- Properties
- Utility methods
Event handlers methods
# === EVENT HANDLERS === #
def _on_config_changed(self, _: ops.ConfigChangedEvent):
"""Handle changed configuration."""
s3_config_data = self._get_s3_storage_config()
self.publish_config(s3_config_data)
def _on_server_cert_changed(self, _):
self._update_cert()
self._ensure_pebble_layer()
self.publish_config(tls=self._is_cert_available)
def _on_mimir_cluster_changed(self, _):
self._process_cluster_and_s3_credentials_changes()
Properties
# === PROPERTIES === #
@property
def hostname(self) -> str:
"""Unit's hostname."""
return socket.getfqdn()
@property
def _is_cert_available(self) -> bool:
return (
self.server_cert.enabled
and (self.server_cert.server_cert is not None)
and (self.server_cert.private_key is not None)
and (self.server_cert.ca_cert is not None)
@property
def mimir_worker_relations(self) -> List[ops.Relation]:
"""Returns the list of worker relations."""
return self.model.relations.get("mimir_worker", [])
Utility methods
# === UTILITY METHODS === #
def has_multiple_workers(self) -> bool:
"""Return True if there are multiple workers forming the Mimir cluster."""
mimir_cluster_relations = self.model.relations.get("mimir-cluster", [])
remote_units_count = sum(
len(relation.units)
for relation in mimir_cluster_relations
if relation.app != self.model.app
return remote_units_count > 1
def publish_config(self, s3_config_data: Optional[_S3ConfigData] = None, tls: bool = False):
"""Generate config file and publish to all workers."""
mimir_config = self.coordinator.build_config(
s3_config_data=s3_config_data, tls_enabled=tls
self.cluster_provider.publish_configs(mimir_config)
if tls:
self.publish_grant_secrets()
Final notes
This kind of comment blocks in the code:
are not mandatory (well, I think almost everything is not mandatory), but helps you to understand at glance what those methods/properties does.
