We have hit the following issue with k8s deployed with juju:
$ juju status
default my1-controller localhost/localhost 2.9.32 unsupported 09:27:34Z
containerd go1.13.8 active 2 containerd stable 178 no Container runtime available
easyrsa 3.0.1 active 1 easyrsa stable 420 no Certificate Authority connected.
etcd 3.4.5 active 3 etcd stable 634 no Healthy with 3 known peers
flannel 0.11.0 active 2 flannel stable 597 no Flannel subnet 10.1.38.1/24
kubeapi-load-balancer 1.18.0 active 2 kubeapi-load-balancer stable 844 yes NGINX is ready
kubernetes-master 1.22.15 active 1 kubernetes-master stable 1078 no Kubernetes master running.
kubernetes-worker 1.22.15 active 1 kubernetes-worker stable 816 yes Kubernetes worker running.
easyrsa/0* active idle 0 10.50.30.221 Certificate Authority connected.
etcd/0 active idle 1 10.50.30.201 2379/tcp Healthy with 3 known peers
etcd/1 active idle 2 10.50.30.248 2379/tcp Healthy with 3 known peers
etcd/2* active idle 3 10.50.30.219 2379/tcp Healthy with 3 known peers
kubeapi-load-balancer/1 active idle 13 10.50.30.223 NGINX is ready
kubeapi-load-balancer/2* active idle 14 10.50.30.222 443/tcp,6443/tcp Loadbalancer ready.
kubernetes-master/0* active idle 5 10.50.30.243 6443/tcp Kubernetes master running.
containerd/4 active idle 10.50.30.243 Container runtime available
flannel/4 active idle 10.50.30.243 Flannel subnet 10.1.34.1/24
kubernetes-worker/0* active idle 7 10.50.30.204 80/tcp,443/tcp Kubernetes worker running.
containerd/1* active idle 10.50.30.204 Container runtime available
flannel/1* active idle 10.50.30.204 Flannel subnet 10.1.38.1/24
0 started 10.50.30.221 juju-e1704d-0 focal Running
1 started 10.50.30.201 juju-e1704d-1 focal Running
2 started 10.50.30.248 juju-e1704d-2 focal Running
3 started 10.50.30.219 juju-e1704d-3 focal Running
5 started 10.50.30.243 juju-e1704d-5 focal Running
7 started 10.50.30.204 juju-e1704d-7 focal Running
13 started 10.50.30.223 juju-e1704d-13 focal Running
14 started 10.50.30.222 juju-e1704d-14 focal Running
$ k get pods -n test
Error from server (InternalError): an error on the server ("<html>\r\n<head><title>502 Bad Gateway</title></head>\r\n<body>\r\n<center><h1>502 Bad Gateway</h1></center>\r\n<hr><center>nginx/1.18.0 (Ubuntu)</center>\r\n</body>\r\n</html>") has prevented the request from succeeding
But if I run exactly the same command (k get pods -n test) a few seconds later it works correctly.
Can anybody tell me what is wrong ?
