As a follow up to the previous elasticsearch post I felt it would be helpful to highlight a few useful elasticsearch lifecycle operations around backup/restore using S3.
Configure undocumented system property
To use s3 as a snapshot repository we need to apply an undocumented system property in the /etc/elasticsearc/jvm.options on all nodes in the cluster.
-Des.allow_insecure_settings=true
To apply this add the key=val to the file.
juju run --application elasticsearch "echo '-Des.allow_insecure_settings=true' >> /etc/elasticsearch/jvm.options"
Configure Elasticsearch to use the S3 repository backend
Set the elasticsearch-keystore values so we can backup/restore a snapshot using an s3 backend.
juju run --application elasticsearch \
"export ES_PATH_CONF=/etc/elasticsearch && echo -n '<aws-access-key>' | /usr/share/elasticsearch/bin/elasticsearch-keystore add --stdin s3.client.default.access_key"
"export ES_PATH_CONF=/etc/elasticsearch && echo -n '<aws-secret-key>' | /usr/share/elasticsearch/bin/elasticsearch-keystore add --stdin s3.client.default.secret_key"
# Restart elasticsearch
juju run --application elasticsearch "service elasticsearch restart"
If you are working with a heterogeneous deploy this would need to be preformed on all node types:
# Master nodes
juju run --application es-master \
# Data nodes
juju run --application es-data \
# Restart elasticsearch on all node types
juju run --application es-master "service elasticsearch restart"
juju run --application es-data "service elasticsearch restart"
Setup the snapshot repository
To backup and index to an s3 location:
curl -X PUT "http://<elasticsearch-node-ip>:9200/_snapshot/<repository-name>" -H 'Content-Type: application/json' -d'
"type": "s3",
"settings": {
"bucket": "<s3-bucket-name>",
"base_path": "<s3-base-path>",
"region": "<region-if-applicable>",
"access_key": "<aws-access-key>",
"secret_key": <aws-secret-key>"
Backup a snapshot of one or more indices to an S3 repository
curl -X PUT "http://<elasticsearch-node-ip>:9200/_snapshot/<repository-name>/<snapshot-name>" -H 'Content-Type: application/json' -d'
"indices": "<indices-to-include-in-snapshot-separated-by-commas>",
"ignore_unavailable": true,
"include_global_state": false
Get the status of the snapshot operation
curl "http://<elasticsearch-node-ip>:9200/_cat/snapshots/<repository-name>"
Restore a snapshot of one or more indices from S3 repository
curl -X POST "http://<elasticsearch-node-ip>:9200/_snapshot/<repository-name>/<snapshot-name>/_restore" -H 'Content-Type: application/json' -d'
"indices": "<indices-to-include-in-snapshot-restore-separated-by-commas>",
"index_settings": {
"index.number_of_replicas": 0
"ignore_index_settings": [
"index.refresh_interval"
Modify index settings
Example of how to modify index settings.
curl -X PUT "http://<elasticsearch-node-ip>:9200/<index-name>/_settings" -H 'Content-Type: application/json' -d'
"index" : {
"number_of_replicas" : 1
