The Juju team is proud to release Juju 2.6.2!
This is a bugfix release in the 2.6 series. It addresses issues that have been encountered relating to upgrading controllers and models defined in Juju 2.4.
This release includes important fixes
- LP 1829014 - juju status and juju upgrade-charm commands returns runtime error: invalid memory address or nil pointer dereference.
- LP 1828332 - Segmentation fault during bootstrap of microk8s-cloud
- LP 1827838 - Multiple jujud services stuck with “uniter” manifold worker returned unexpected error: failed to initialize uniter cannot create storage hook source
How do I get it?
The best way to get your hands on this release of Juju is to install it as a
snap package
Other packages are available for a variety of platforms. Please see the online documentation at https://docs.jujucharms.com/reference-install. Those subscribed to a snap channel should be automatically upgraded. If you’re using the PPA or have installed Juju via homebrew, on macOS you should see an upgrade available.
Feedback Appreciated!
We encourage everyone to let us know how you’re using Juju. Join us on Discourse at https://discourse.jujucharms.com/, send us a message on Twitter using the hashtag #jujucharms, and join us at #juju on Freenode.
