Perhaps try changing the syntax? Yours looks correct though, so I’m a little confused too:
series:
- focal
series:
- focal
I’ve made that but the issue is the same:
summary: Riccardo MAgrini
maintainer: Riccardo Magrini <Riccardo.Magrini@maas>
description: |
This is my first JUJU charm
series:
- focal
then
$:charm proof nginx-lab/
I: `display-name` not provided, add for custom naming in the UI
E: missing series: must be a list of series names
I: all charms should provide at least one thing
in the Ubuntu 18.04, as reported in my first post of this discussion, I’ve used the same syntax. So it’s my first time I try to create a charm.
Remove any spaces before “series”:
description: |
series:
- focal
@timClicks thanks a lot, now it’s work
someone can explain me these lines:
$:charm build nginx-lab
build: Please add a `repo` key to your layer.yaml, with a url from which your layer can be cloned.
proof: I: `display-name` not provided, add for custom naming in the UI
thanks a lot
Those are informative items letting you know that good quality charms adds this information to the charm.
the first one as reports the informative is on layer.yaml but the second one where I’ve to add it
thanks
