Work offline
The objective of this page is to assist users who find themselves deploying and/or managing Juju within an offline network.
For the purposes here, a network is considered offline if the systems on that network have been deliberately deprived of access to any outside network, the internet in particular. This is typically done for security reasons.
Such a network can also be called a proxy-restricted environment since, normally, access is allowed to a few internet-enabled systems that act as intermediaries (proxies) for necessary services. In a Juju context, such services would commonly provide access to:
  • charmed operators
  • APT packages
  • Various HTTP-based resources
  • snaps
This page will cover the following topics:
Examples of common offline clouds are LXD, MAAS, and OpenStack.
This subject is broken up into several sub-topics, each with its own page. They all assume Juju has been installed on a system dedicated to the management of the offline environment.
Offline mode strategies
This section will offer guidance at the system administrator level by describing what resources/protocols are required by various types of Juju deployments. In addition, suggestions for achieving the corresponding services are offered by means of HTTP/S proxying, APT proxying, and repository mirroring, Juju agent mirroring, and cloud image mirroring. See Offline mode strategies.
Configuring Juju for offline usage
Juju needs to be configured in order for its various parts (client, controller, machines) to know how to request the resources necessary for various actions (controller creation, machine creation, charmed operator deployments, etc.) to be successful. This section will show how this is done via the CLI. See Configuring Juju for offline usage.
Deploying charmed operators offline
Once the auxiliary services have been set up and Juju has been configured to use those services Juju charmed operators can be deployed. This section describes how this is done. See Deploying charmed operators offline.
Installing snaps offline
The exemplar snap for Juju users is charmed Operator Tools but the guidance provided here can be applied to any snap. See Installing snaps offline.
Using the localhost cloud offline
Here, an example of an offline Juju installation is provided through the use of the localhost cloud (LXD). Go to Using the localhost cloud offline.
