WIP: Juju 2.9.0 Release Notes
The Juju team is proud to release Juju 2.9.0. We aim to be your preferred tool for writing operators, software that manages software, whether your hosting infrastructure is Kubernetes, in the cloud or on-premise.
2.9 Highlights
New Features
Juju 2.8.0 includes extra features for people using Juju as well as those writing charms for Juju.
Other changes
  • Juju has rectified some modeling issues for Kubernetes clusters where previous version where using incorrect data to model credentials. Because if this change Juju 2.9 now creates different Kubernetes cloud credentials that are not backwards compatible with Juju releases pre 2.9
More Details
Issues Resolved
This release includes several fixes. Issues triaged as Critical and High are listed here, other issues are available from the milestone’s page.
Known Issues
Juju 2.9.0 contains a small number of known issues that require workarounds to overcome.
  • Juju clients pre 2.9 will know longer work full with Juju 2.9. We recommend upgrading all clients to Juju 2.9
How do I install Juju?
sudo snap install juju --channel=stable --classic
Other packages are available for a variety of platforms, including Windows and macOS. Refer to the full Juju installation documentation.
Those subscribed to a snap channel should be automatically upgraded. If you’re using the PPA or Homebrew for macOS, you should see an upgrade available.
How do I upgrade?
Upgrading Juju is a multi-step process:
  • upgrade the client (the Juju binary that you interact with on the command-line)
  • (recommended) verify that the client upgrade was successful
  • (recommended) back up the controller
  • upgrade the controller
  • upgrade models
Upgrade the client
If you’ve installed Juju via the snap, your Juju will automatically be installed overnight. To force the update, run:
snap refresh juju  --channel=stable
Check version
To prevent any confusion in later steps, ensure that you’re using the new Juju version.
juju version
Check your $PATH environment variable and that you’ve installed the new version correctly.
On Linux and macOS, use the env command to inspect the environment. On MS Windows, use SET.
Backing up
The controller state can be saved to allow for recovery in case the upgrade process encounters a serious error. The juju create-backup command operates within the controller model and will download the controller’s state to the local machine.
juju switch controller
juju create-backup
Upgrading controllers
Juju includes a command that instructs the controller to upgrade itself to the latest version. Because this release is a release candidate, we need to change the “agent stream” to download the new version of the Juju agent.
juju upgrade-controller
How to upgrade the controller
First, check that you’re interacting with the intended controller. The juju models command reports the current controller on the first line.
juju models
To verify what will occur, use the --dry-run option.
When you’re happy, omit the flag:
Upgrade models
Your models remain at the same version until you have explicitly told Juju to upgrade them.
juju upgrade-model -m <model-name>
How to upgrade your model(s)
Check that you’re operating in the correct model. juju model highlights the current model with an asterisk:
juju models
juju upgrade-juju --dry-run
juju upgrade-juju
Further instructions
Juju’s documentation pages provide detailed information about the upgrade process:
Feedback Appreciated!
We encourage everyone to let us know how you’re using Juju. Please ask questions on on Discourse, send us a message to our Twitter account @juju_devops, tweet using the hashtag #juju_devops, and chat with us at #juju on Freenode via IRC or Matrix.
2.8.0? Typo?
