This page is dedicated to more advanced topics related to using Microsoft Azure with Juju. The main page is here.
Manually adding Azure credentials
The manual option is useful if Juju fails to automatically gather your credentials, or if you want to automate the process.
Gathering values
We will need values for the following bits of information:
- subscription id
- application name
- application id
- tenant id
- application password
In the sections below, we will assign each of these a variable name. When you enter them into the command, replace the variable name we give with the actual ID that corresponds to the variable.
This process requires the Azure CLI tool to be installed and used to successfully log in to Azure prior to Juju configuration. See Install the CLI tool and Log in to Azure respectively.
subscription id
List your account and take note of the subscription ID, the SUB_ID.
az account list
It will appear on the line labelled id:
"cloudName": "AzureCloud",
"id": "27dcbd27-c935-43f4-a1b5-123456722c00",
"isDefault": false,
"name": "Microsoft Azure Enterprise",
"state": "Enabled",
"tenantId": "558ac724-0c20-4c6b-ab00-12345679b6f0",
"user": {
"name": "javierlarin72@gmail.com",
"type": "user"
"id": "bef58c0a-6fca-489d-8297-12345677f276",
"isDefault": true,
"name": "Pay-As-You-Go(Converted to EA)",
"state": "Enabled",
"user": {
"type": "user"
In this example, there is a Pay-As-You-Go (PAYG) subscription that has been converted to an Enterprise Agreement (EA), which refers to the other stanza (Microsoft Azure Enterprise). It seems we should always choose the PAYG subscription id, so:
SUB_ID=bef58c0a-6fca-489d-8297-12345677f276
application name
You will need to come up with an arbitrary application name (typically an internet URL). In our example:
APP_NAME=http://ubuntu.example.com
Now create an Active Directory (Kerberos) service principal and assign it a role of Owner:
az ad sp create-for-rbac --name "$APP_NAME" --role Owner
The command output will be similar to the following:
"appId": "c07fd75f-dc07-47a1-87ed-123456731897",
"displayName": "azure-cli-2019-05-22-02-01-44",
"name": "http://ubuntu.example.com",
"password": "76ab0f15-4d2e-4dd8-abca-1234567325d5",
"tenant": "558ac724-0c20-4c6b-ab00-12345679b6f0"
For more in-depth information, see Microsoft’s Azure CLI documentation on Role-Based Access Control (RBAC) and the above commmand’s syntax.
application id, tenant id, and application password
From the previous output we obtain the following values for application-id
, tenant-id
, and application-password
APP_ID=c07fd75f-dc07-47a1-87ed-123456731897
TENANT_ID=558ac724-0c20-4c6b-ab00-12345679b6f0
APP_PASSWORD=76ab0f15-4d2e-4dd8-abca-1234567325d5
Verification of values
You can verify the values we’ve collected by logging in using the application principal as your identity:
az login --service-principal -u "$APP_NAME" -p "$APP_PASSWORD" --tenant "$TENANT_ID"
Command output will look similar to the following:
"isDefault": true,
"state": "Enabled",
"user": {
"type": "servicePrincipal"
Add credentials
Credential information can now be placed into a YAML file and used with a client. Here, we’ve assigned a credential name of ‘jlaurin’:
credentials:
azure:
jlaurin:
auth-type: service-principal-secret
application-id: c07fd75f-dc07-47a1-87ed-123456731897
subscription-id: bef58c0a-6fca-489d-8297-12345677f276
application-password: 76ab0f15-4d2e-4dd8-abca-1234567325d5
To add credential ‘jlaurin’, assuming the configuration file is creds.yaml
in the current directory, we would run:
juju add-credential azure -f creds.yaml
Next steps
You should now continue reading the main Using Microsoft Azure with Juju page at the controller-creation step.
If you add more than one credential you will need to either specify one while creating the controller (juju bootstrap --credential
) or set a default (juju set-default-credential
) before doing so.
