Using GitLab as a container registry for Kubernetes
Overview
Container orchestration solutions such as Kubernetes allow development teams to be quick and agile with their software deployments. The main feature of these orchestration tools is the ability to reduce the deployment of version piece of software down to a simple tag name on the end of a string. For example image: someApplication:canary.
This opens the doors to streamlined deployments, but creates another problem. How do we streamline? We can do this manually, but it’s not very streamlined. Or we can do this automatically, but we need to be smart. We can’t just deploy as soon as a new version is released. We need to check it first. This is where container registries and CI/CD come in.
GitLab can store up to 10 GB in a container registry for projects. You can incorporate the building of these containers into your own CI/CD pipeline or you can use Gitlab’s own CI/CD functionality to do this for you. For this tutorial, you will do this by hand so you can get a grasp of the process.
In this tutorial you’ll learn how to:
  • Create a private container registry on GitLab
  • Create deployment keys
  • Create a container
  • Push to the container registry
  • Pull using your deployment key
You will only need
  • Kubernetes cluster
Find yourself a healthy Kubernetes cluster. If you don’t have access to one, install MicroK8s on your laptop at no cost. If you’re on Windows or Mac you may need to follow the Multipass guide first to get a VM with Ubuntu before you start.
Charmed Kubernetes
Process
To create your container registry on GitLab you will need to complete the following steps:
  • Create a project
  • Add a Dockerfile
  • Enable Container Registry
  • Build our image
  • Push our image
  • Create a token
  • Pull our image
These steps will create a private registry, but you can use them as a guide for a public registry, just miss the deployment token steps.
Choose or create a project
Duration: 3
To begin with, you can use an existing project or create a new one. I will be creating a new project called gitlabregistries, for the purposes of experimentation, you will create a private project.
Creating a gitlab project
Grab the git repository address and clone the repository to a directory of your choice.
Cloning the repo via ssh
Create the docker file
Firstly, get a terminal inside of the newly cloned directory:
Terminal on open on the repository
To set up our shell project, you are going to do two things: create the dockerfile and add a small program to show that our image has deployed to Kubernetes.
Let’s start with the program:
vi main.py
Add these lines to the new file:
import time
def main():
    while True:
       print("Ubuntu runs containers!")
       time.sleep(5)
 if __name__ == "__main__":
     main()
Now that is done you can move onto the Dockerfile:
vi Dockerfile
Add these lines:
FROM ubuntu:latest
RUN apt-get update && apt-get -y install python3
COPY ./ /opt/vb
CMD [“python3”, “/opt/vb/main.py”]
You can now build our container, but before this, you need to enable container registries on Gitlab and grab the URL. Here we have a screenshot of an already enabled projected, but you can find the settings to enable in Settings > General > Visibility, project features, permissions and press the expand button.
Gitlab visibility and permission settings
Build our container
Duration: 5
The command here to build can be copied and used in your terminal:
docker build -t registry.gitlab.com/<YOUR_USERNAME>/gitlabregistries .
Before you can push to the repository you need to login to docker:
docker login registry.gitlab.com -u <USERNAME>
You should see a message similar to this if the login was successful:
Successful login
Push our container
Duration: 5
We can then push to our project’s repository:
docker push registry.gitlab.com/<YOUR_USERNAME>/gitlabregistries
Pull our container
Duration: 10
Create a token
Before you can pull from the private repository a secret for Kubernetes needs to be created to allow pulling:
In this case, I have used the username k8s, take note of the token, and following the Kubernetes documentation, you can create a new secret:
kubectl create secret docker-registry regcred --docker-server=registry.gitlab.com --docker-username=k8s --docker-password=<token>
Run kubectl get secret regcred just to check, mine looks like this:
apiVersion: v1
data:
  .dockerconfigjson: eyJhdXRocyI6eyJyZWdpc3RyeS5naXRsYWIuY29tIjp7InVzZXJuYW1lIjoiazhzIiwicGFzc3dvcmQiOiJ6enJQNk0zUEJkX0tuZE5INmt1cCIsImF1dGgiOiJhemh6T25wNmNsQTJUVE5RUW1SZlMyNWtUa2cyYTNWdyJ9fX0=
kind: Secret
metadata:
  creationTimestamp: "2019-08-30T13:55:11Z"
  namespace: default
  resourceVersion: "19552"
  selfLink: /api/v1/namespaces/default/secrets/regcred
  uid: be61c809-1572-431f-8a73-43c80e934923
type: kubernetes.io/dockerconfigjson
Now you can create a deployment with our newly uploaded container image:
kubectl create deployment gitlabrepositories --image=registry.gitlab.com/<YOUR_USERNAME>/gitlabregistries
Now wait for it to come up:
watch kubectl get pods
Initially, Kubernetes will fail to pull the image, and you should see something like this:
gitlabrepositories-86d4b9bf87-q86rx   0/1     ImagePullBackOff    0          3m39s
This is because there’s no secret, you need to edit the deployment:
kubectl edit deployment gitlabrepositories
Under the containers spec you need to add imagePullSecrets so that it looks something like this:
     spec:
       containers:
       - image: registry.gitlab.com/variabledeclared/gitlabregistries
         imagePullPolicy: Always
         resources: {}
         terminationMessagePath: /dev/termination-log
         terminationMessagePolicy: File
       dnsPolicy: ClusterFirst
       imagePullSecrets:
       - name: regcred
Check the pods again, your container should now have started.
If your pod has started then let’s check the logs for logging!
kubectl logs -f <YOUR_POD_NAME>
Hmm, there seems to be a problem:
No logging on the pod
I forgot something! But that’s fine because you have a (semi) automatic process setup now. Let’s go into the docker file and add this line just before CMD:
ENV PYTHONUNBUFFERED=0
Rebuild:
docker build -t registry.gitlab.com/<YOUR_USERNAME>/gitlabregistries:v1 .
Push:
docker push registry.gitlab.com/variabledeclared/gitlabregistries:v1
And update our deployment with the new image tag:
   spec:
       containers:
       - image: registry.gitlab.com/variabledeclared/gitlabregistries:v1
         resources: {}
       imagePullSecrets:
       - name: regcred
       restartPolicy: Always
       schedulerName: default-scheduler
       securityContext: {}
      terminationGracePeriodSeconds: 30
OK lets check the logs now:
Program is logging
Voila!
That’s all folks!
In this tutorial, you learnt how to use GitLab as a container repository, albeit with some human labour involved. You can checkout GitLab’s documentation on how to take your newly learned skills and apply them to your own CI/CD or create one in GitLab.
If you don’t wish to use a private repository then you can use these steps as a guide, ignoring the generate token steps.
Where to go from here?
Under “Create the docker file”
Suggest adding instructions for people who use the Nano editor vs VIM
Within “Build our container”
Duration: 5
Suggest adding instructions for people who use 2FA whereby they are required to create an API key/Access token for loging-in to GitLab
