This is in connection with the Working with multiple users page. See that resource for background information.
There are three types of Juju users that we can speak of: controller administrators, model owners, and regular users. Each user, no matter the kind, is associated with one, and only one, controller.
A controller administrator is a user who has full access to the ‘controller’ model. This set of users is comprised of the controller creator and any user the latter user has granted ‘superuser’ access to the ‘controller’ model. There is no overarching “Juju administrator” since multiple controllers, and therefore multiple controller administrators, are possible. Nevertheless, this user is usually what people refer to as “the admin”.
A model owner has some specific administrative powers over a model. By default, the owner is the model creator but an owner can also be explicitly assigned during creation-time.
A regular user is one who is neither a controller administrator nor a model owner. Such a user requires access to a model in order to do anything at the Juju level.
The operator is a term used to refer to the actual person who is driving the Juju client.
The different Juju user types have different abilities based on permissions. They are outlined below. For completeness, the abilities of system users and newly-created users are also included.
System users
Actions available to a system user and the corresponding Juju commands:
- Access help (
help
) - List supported cloud types (
clouds
) - Show details on each cloud type (
show-cloud
) - Connect to a controller (
register
) - Add credentials (
add-credential
andautoload-credentials
) - List credentials (
credentials
) - Create controllers (
bootstrap
Once a system user has created a controller they are provided automatically, at the Juju level, with an administrator of that controller and inherit all the privileges of that user type (see below).
Since any system user can add credentials and create controllers, it is conceivable that multiple controllers exist that use the same cloud resource (public cloud account). Although this will work with Juju, it is a policy decision as to whether this should be allowed.
Newly-created users
A newly-created user is automatically granted login access to the controller. Once logged in, the user is allowed to perform additional actions:
- Log in to a controller (
login
) - List the user (
users
) - Show details for the user (
show-user
) - Log out of a controller (
logout
To do anything further the user must be granted some level of access to a model or be given superuser access to the controller.
Controller administrators
Only a controller administrator (the “admin”) has the power to perform these actions (in the context of their controller):
- Add users (
add-user
) - Disable users (
disable-user
) - Enable previously disabled users (
enable-user
) - Create models (
create-model
) - Grant and revoke user access to clouds (
grant-cloud
andrevoke-cloud
) (v.2.6.0
) - Grant and revoke user access to models (
grant
andrevoke
) - Remove models (
destroy-model
) - Remove the controller (
destroy-controller
orkill-controller
) - Upgrade models (
upgrade-model
) - Manage controller backups (e.g.
create-backup
Model owners
A model owner can list users who have access to the model (users
), destroy the model (destroy-model
), and upgrade the model (upgrade-model
Regular users
The ability of a regular user depends on the model access rights (‘read’ or ‘write’) they have been granted.
For read-only access, the user can do the following:
- List models (
models
) - List machines (
machines
) - Show the status (
status
For write access, the user can use Juju as an operator, beginning with the following major actions:
- Deploy applications (
deploy
) - Scale out applications (
add-unit
External users
External users are those users that exist on a remote authentication system. Currently, a controller can offload user authentication to https://jujucharms.com
only. This is done by passing the ‘identity-url’ key at controller-creation time with a value of https://api.jujucharms.com/identity
It is possible to have a controller use an authentication system other than the one given above, but such a design is not supported at this time.
The enabling of the external identity URL does not negate the standard local aspect of user authentication. That is, both local and remote users can log in.
See tutorial Multi-user external setup for a quick walkthrough.
