Tutorial: Charm development (Beginner, part 2)
Difficulty: Beginner Author: Erik Lönroth
What you will learn:
Building on the previous tutorial: Tutorial: charm development, Beginner: Part 1. In this part, you will:
- Learn about the “layer-index”.
- Learn how to add a ‘mysql’ database interface to charms.
- Write a charm that writes a text-file using a template.
- Deploy the example charm and relate to a mysql charm.
- Use ‘juju ssh’ to login to the juju unit and display the contents of the text-file.
The ‘layer-index’
Lets examine the includes tag in layer.yaml
includes:
- 'layer:basic'
- 'layer:apt'
You learned from the first part of the tutorial that the ‘includes’ tag in ‘layer.yaml’ is similar to an “include” statement in python. All charms must include the ‘layer:base’.
The build system will add in code from the ‘include’ tag with our own.
Alot of already existing juju functionality can be found in the layer-index. Take a look and see if you find some interesting features you like to explore later.
As you see, we have also already added the layer:apt.
Since we can include both ‘layers’ and ‘interfaces’ lets see how that is done.
Add the interface:mysql
To add the mysql interface, we have to:
- Modify ‘layer.yaml’
- Modify ‘metadata.yaml’
- Create a template inside a templates directory.
Lets do that.
Modify the ~/charms/layers/layer-example/layer.yaml to look like this:
includes:
- 'layer:basic'
- 'layer:apt'
- 'interface:mysql'
options:
apt:
packages:
- hello
Modify the ~/charms/layers/layer-example/metadata.yaml to look like this:
summary: A very basic example charm
maintainer: Your Name <your.name@mail.com>
description: |
This is a charm I built as part of my beginner charming tutorial.
tags:
- misc
- tutorials
requires:
database:
interface: mysql
Create the templates directory:
The ‘templates’ directory is where templates go for charms. Lets create it.
cd ~/charms/layers/layer-example/
mkdir templates
Modify the ~/charms/layers/layer-example/templates/text-file.tmpl to look like this:
DB_HOST = ‘{{ my_database.host() }}’ DB_NAME = ‘{{ my_database.database() }}’ DB_USER = ‘{{ my_database.user() }}’ DB_PASSWORD = ‘{{ my_database.password() }}’
The file above is in a “Jinja2” template format. Jinja2 templates allows us to perform very advanced template rendering with little effort.
Rewrite the layer_example.py
~/charms/layers/layer-example/reactive/layer_example.py
from charms.reactive import set_flag, when, when_not
from charmhelpers.core.hookenv import application_version_set, status_set
from charmhelpers.fetch import get_upstream_version
import subprocess as sp
from charmhelpers.core.templating import render
@when_not('example.installed')
def install_example():
set_flag('example.installed')
@when('apt.installed.hello')
def set_message_hello():
# Set the upstream version of hello for juju status.
application_version_set(get_upstream_version('hello'))
# Run hello and get the message
message = sp.check_output('hello', stderr=sp.STDOUT)
# Set the maintenance status with a message
status_set('maintenance', message )
# Signal that we know the version of hello
set_flag('hello.version.set')
@when('database.available')
def write_text_file(mysql):
render(source='text-file.tmpl',
target='/root/text-file.txt',
owner='root',
perms=0o775,
context={
'my_database': mysql,
status_set('active', 'Ready: File rendered.')
@when_not('database.connected')
def missing_mysql():
status_set('blocked', 'Please add relation to MySQL')
@when('database.connected')
@when_not('database.available')
def waiting_mysql(mysql):
status_set('waiting', 'Waiting for MySQL')
What happens here is that:
- We install the ‘hello’ package, just as we did in the first part of the tutorial.
- The mysql interface raises a flag ‘database.available’ when the relation is joined, mysql has created a database, a username and password for us.
- The database mysql object with the information we need is passed to us from the juju interface.
- We pass on the mysql object to Jinja2 render() that renders the template.
- We finish our work by setting the ‘active’ status.
What is the difference from tutorial part 1?
Look at the code in the function set_message_hello(). In the previous part of this tutorial, we set the ‘active’ status when the hello package was installed which was all we wanted our charm to do at that point.
However, in this part of the tutorial, we set status to ‘maintenance’ instead so we can do more work without signaling that we are ‘active’.
Status is set to ‘active’ in the function write_text_file(mysql) when the template is rendered which is the goal for this charm.
owner='root',
perms=0o775,
context={
We are ready to rebuild.
Proof, Build, Deploy, Relate
We are done and can run through the build, deployment and try relate our charm to the mysql charm.
cd ~/charms/layers
charm proof layer-example
charm build layer-example
juju deploy ../trusty/example
juju deploy cs:mysql
juju relate example mysql
Note: We deploy our local charm by referencing with a path (…/trusty/example). mysql is on the other hand is deployed from the Charm Store (cs:mysql). “cs:mysql” tells juju to download the charm from over the network instead of uploading it from our local directory repository.
Look at the file with ‘juju ssh’
Lets look at the file we created inside the example/0 unit. We will do that using “juju ssh”.
juju ssh example/0 sudo cat /root/text-file.txt
juju ssh executes a command on the remote machine and if everything goes well, you should see the contents of the rendered file, something like below:
DB_HOST = ‘10.170.55.25’ DB_NAME = ‘example’ DB_USER = ‘Dae7EGh9Zei0nee’ DB_PASSWORD = ‘aiRei1siePhewah’
Congratulations, you have completed the second part of the tutorial!
Next lesson:
In the next tutorial you will learn how to publish your charm to the charmstore so you can use it from anywhere around the world, in any cloud!
Move on to the next part of the tutorial series in Part 3.
