Right, I will remove the JUJU_REPOSITORY variable entirely then to reduce any implicit needs for a beginner.
@munir12 I’ve taken your advice and if you like to have a look at my new thread here: https://discourse.jujucharms.com/t/charm-problems-with-bash-hooks/1229
when you run charm create layer-example
, it will actually use layer-example
as the final charm name, which is not as expected.
After charm build layer-example
, you will get:
- a charm named
layer-example
in~/charms/builds/
- In metadata.yaml of the charm, you will see
- in
reactive
dir, you wil see filelayer-example.py
, andapt.py
for layer-apt, which are inconsistent in names. - in
layer-example.py
, you will see flaglayer-example.installed
and hook funcdef install_layer_example()
, while apt layer doesn’t work with names like that.
There are more examples like above, in which the prefix layer-
should not exist. I think the prefix layer-
should only be used for repo name. So a smooth process to create a layered charm will be:
cd ~/charms/layers
charm create example
# edit files in example/
# create git repo `layer-example` and push
charm build example
cd ~/charms/builds/example
# deploy or push to charm store
You are probably right here. Its probably worth fixing too.
I got:
sudo juju deploy ./example
ERROR invalid charm “example”: has no hooks
Any suggestion how to fix it?
Hello and welcome to the community.
To be able to help, could you provide a bit more context?
A separate suggestion is to avoid running juju as the root user. Sudo is a powerful tool, and it can (and will) create problems for you.
