Hi @noobadmin
Not sure how the k8s cloud was added. The host-cloud-region was missing in your cloud.
When running add-k8s, Juju should have asked the cloud.
# cloud is required and it should be maas if the CK is running on maas.
# region is required as well but maas does not really have region, so just use any fake region.
juju add-k8s k8s-cloud --local --cloud=maas --region=<fake-region>
Then Juju knows current base cloud is maas, so it will create the Load Balancer service type for the controller.
If the kubeapi-load-balancer configured correctly, it should just work.
Here are the results, unfortunately I didnāt manage to do any valuable progress.
more about my akward networking setup:
powerful but non-enterprise asus home router with dhcp off, custom dnsmasq to redirect pxe to maas. single ethernet each node.
āmaster nodeā has static address, routerās ip set as gateway and dns(!) - behind a corporate network, 8.8.8.8 is unreachable. Maas provides dhcp and dns is set as authoritative.
juju controller is running inside an lxd container. Iāve added lxd with the add kvm button in maas after doing lxd init. That itself was pain, I got the containers sort of working with a custom bridge (Ubuntu Pastebin). Their behaviour is akward. If I launch a container with lxc, its ip address (assigned by maas) shows up in lxc, however if I launch an instance from maas dashboard, its ip only shows up in there. I can ssh to those containers and they have access outside. lxc profile: Ubuntu Pastebin
This is a new topic for me and at this point seems at least a little too broad. Where should I continue looking regarding networking? I would guess the dns might be mostly responsible, however I remember I needed to edit some of bind9 configs a couple years ago and I do not have very pleasant memories on that⦠Guidance welcome
Hi @noobadmin
Sorry, I am not very familiar with maas.
As I mentioned above, bootstrap should be just working if a normal LoadBalancer service works on the CK running on the maas.
You can have a test to see if the networking works or not.
