The key differences between vault-operator version 1.8 and 1.15
key differences between version 1.8 and 1.15
Versions 1.8 (and below) and 1.15 (and beyond) are fundamentally different charms. Here is a list of additions, changes and removals made to the Vault charm 1.15, when compared with 1.8.
Additions
Changes
  • TLS Certificates integration: The charm now implements the provider side of the TLS Certificates Integration V1 instead of V0 . This new version of the interface is more secure and only contains public information (CSR’s and Certificates).
  • Storage backend: The Vault charm now supports the Raft backend and drops support for other backends. Raft provides High Availability by default (see Explanation: High Availability).
Removals
  • Providing the snap channel explicitly: Snap revisions are frozen to the charm revision providing reliable deployments.
  • Loadbalancer integration
Upgrading from 1.8 to 1.15
Upgrading from 1.8 to 1.15 is not supported, however you can backup your data on 1.8, and restore it on a new deployment of Vault 1.15.
@yazansalti I removed the - Providing certificates for multiple domains. from the removals section as I didn’t see how the old Vault charm could do this. Feel free to add it back if you figure it out.
