Telemetry
Telemetry is the automatic recording and transmission of data from remote sources. In Juju, it specifically refers to the gathering of routine business metrics with the purpose of helping developers improve Juju. This happens automatically once a day, on a per model basis. For more details, see below.
No user information is gathered.
What data is collected?
  • For a controller
    • juju version
    • controller uuid
  • For a model
    • number of applications
    • number of units deployed
    • number of machines deployed
    • cloud
    • cloud provider
    • cloud region
    • model uuid
  • For a charm
    • number of units
    • names of charms the charm is related to
What is the data used for?
The data will help us gain a better understanding of how Juju is used in the field:
  • Are most configurations using high availability for the controller?
  • Are many models with few units more popular than few models with many units?
  • How many models are used with a controller?
  • Which clouds are the most popular?
  • What charms are frequently used together?
For example, we can better design improvements, create new bundles for charms commonly used together, etc.
Eventually, some data, such as the names of the charms an application is related to, will also be available to charm authors for use in improving their charms.
How do I disable data collection?
To disable telemetry in a juju model, set the disable-telemetry model configuration key to true:
juju model-config disable-telemetry=true
See more: How to manage configuration values for a model
Could you please make this “telemetry” opt-in instead of on by default?
This is seen as “shady” and can be a problem in enterprise environments.
Unfortunately juju has no way to ask the admin at install nor upgrade, if they wish to telemetry to be enabled or disabled. Or any other questions. Therefore we’d almost never get any data, unless an admin found the flag and decided to enable it.
At least this way, documenting the option and adding to release notes, an admin has the option of disabling the feature.
